Mad Professor
Reg: 12-30-08
08-29-19 03:55 AM - Post#2774370
Trying to get horn working for RMV inspection.
Horns work with jumper from battery.
Horns work with plug to horn relay jumped (big wires, hot to horns)
Horns work with relay hooked up and wire to column grounded (relay O.K.)
Horns don't work with horn button on column
Horns come on when steering wheel turned (short to ground someplace inside column).
I just got a puller for the steering wheel so that will be next. The parts for horn button seem in order. Jumping to ground here horn does not work.
My question is where do I look for short/open once steering wheel is off? There seems to be a likely part, the canceling cam that also has the horn contact parts (spring/plunger/button).
How does wire from relay into column complete/hook up here?
Should battery be disconnected to work on this or can I just unplug the relay?
62 Willys wagon
67 CJ5 Buick V6 w/OD
89 S10 baja package
Senior Chevytalk Moderator
08-29-19 04:03 AM - Post#2774373
In response to Mad Professor
Check the contact spring. Usually corrosion or spring length are issues. Clean the horn button contact point. The part under the emblem cover.
Mad Professor
Reg: 12-30-08
08-29-19 04:26 AM - Post#2774376
One more question.
I had the column apart years ago on my 1989 S10 w/tilt column. I needed a special tool to compress a lock plate on the steering shaft so I could remove install a snap ring.
This C10 does not have tilt column. Will I still need above tool if I need to probe deeper into column? I want to have parts/tools in hand if possible as will need this truck to get to parts store.....
62 Willys wagon
89 S10 baja package
08-29-19 12:16 PM - Post#2774420
Yes, a u shape tool is needed press the plate down. I use a piece of uni strut and the column bolt to press it down.
Mad Professor
Reg: 12-30-08
08-31-19 07:01 AM - Post#2774556
Can I pull the spring and contact parts with removing the lock plate?
This is a PITA as have to take a bike or bus to get parts/tools.....
Also I have a spare column from a 78 C10, non-tilt, will parts interchange?
62 Willys wagon
89 S10 baja package
Edited by Mad Professor on 08-31-19 07:03 AM. Reason for edit: No reason given.
Mad Professor
Reg: 12-30-08
08-31-19 09:15 AM - Post#2774564
I just got back, bus/bike, with tools and some parts.
I'm not sure where stuff is shorting/horn on, when I turn steering wheel. Horn button don't work.
The new turning cam did not come with the parts that contact the horn button . That sucked, tomorrow and a 10 miles bike ride if that is fubar parts. But do have a parts column that could be a donor (1978). I have the compessor for the streering locking plate to do that now.
I almost want to McGuyver a button/switch at this point
62 Willys wagon
89 S10 baja package
Mad Professor
Reg: 12-30-08
09-07-19 02:27 PM - Post#2775017
Update on horn fix.
This is an 1985 that I purchased but never had on the road/inspected.
I took off the horn button parts, and the contact with the spring that goes down to the the turn signal canceling cam, was installed wrong. This is probably why prior owner disconnected the horn relay. As it would beep if you turned the steering wheel.
He had the spring in first, then the plastic retainer, with the contact upside down.
I corrected that. It was a PITA to get the plastic retainer pushed down and turned so it locked in place. I used a pair of fine point medical forceps.
I still had some issues with either the horn not working or staying on. I took the horn button parts from a spare 1978 column and cleaned up all the surfaces. All is well now and I didn't have to pull the column apart.
I now have some questions about backup light switch but I'll start a new thread for that.
Thanks for the advice gchemist!
62 Willys wagon
89 S10 baja package
09-09-19 05:07 AM - Post#2775119
Nice find. I know about the spring because it has cause me trouble too.
