Username Post: Am I Crazy        (Topic#357855)
badbob85037
Loc: Arizona
Reg: 03-13-09
08-28-19 07:27 PM - Post#2774360
Last month I was bragging how I had nothing leaking under my 74 K-10. Took it out did a little 4 wheeling, my spare is a little to worn to 5 wheel. Came home on the freeway doing about 70 MPH for around 35 miles. Did a little more bragging as I pulled into the drive way about no leaks. I got out and oil had poured from the whole right side of the truck. I'm sure it came from blow by. over a qt.
I first ran a compression check and it was fine. I pulled the valve covers and made sure I had no restrictions in the oil passages. I rebuilt the 1990 350 a couple years ago and my emission readings are near zero. It hasn't done it since then but does anyone have a clue as to why it happened? My bragging?
Senior Chevytalk Moderator
08-29-19 04:01 AM - Post#2774372
    In response to badbob85037
Where did the oil come out? Check the intake rear. At steep angles, a small gap there will spill oil. Is the dipstick in place securely? Is the PVC valve working properly?
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
08-29-19 11:37 AM - Post#2774417
badbob,
motor oil, or ATF?
Griff
1960 Biscayne (the 6T)
2005 Yukon XL
2007 GMC Sierra Classic 8.1
2009 Silverado
2011 Escalade ESV
2plus2
Loc: Mission,BC
Reg: 02-03-05
08-29-19 01:15 PM - Post#2774423
    In response to beagrizzly
Is it gear oil from the front diff?
Where is the vent ran to?
69 Canadian Pontiac 2+2
Whitetail Hunter
"2nd Year" Platinum Supporting Member
Whitetail Hunter
Loc: Green Bay Wisconsin
Reg: 03-28-15
08-30-19 07:09 PM - Post#2774534
We're all crazy. It's not a competition....
Execution time: 0.111 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:38 PM
