Username Post: fuel pressure not holding        (Topic#357850)
george88gta
george88gta
Loc: new york
Reg: 04-23-03
08-28-19 03:59 PM - Post#2774325
2001 s-10 4.3l 135000 mi. Friends truck. It has slow start and stumbling. I havent really dug in to this yet, but an initial check of the fuel pressure shows that as soon as the pump stops (just turning the key on/off, not starting the engine) the pressure goes to zero. With the pump running, the fuel pressure is around 55-60 psi. Not familar with these fuel systems, but I know that on my TPI engines, the fuel pressure holds for a long time. If it dropped, we would change out the pressure regulator. Same rule here or does this system work differently? Plan is to go over the entire system to look for leaks, etc. There is no smell of fuel anywhere, not even in the engine oil. If it was a defective injector, shouldnt we be seeing exhaust smoke of fuel in the oil?
Truck acts strange, gauges move erractically and he occassionally gets a low fuel light with a full tank of fuel. Truck is rusty, plan is to go over all the grounds to see if corrosion is a factor. I will check the fuel filter. He said the fuel pump was replaced a few years ago, so hopefully that is not a contributing factor. Not much to go on, but any ideas as to where to start? We will be looking at this over the weekend ( time permitting).
08-30-19 04:34 AM - Post#2774456
    In response to george88gta
It should hold pressure after shutting down. The fuel pressure regulator is bad. Is the fuel pump original? It may be time for a new one.
You can unbolt the bed for tank access.
'08 GMC Acadia 3.6L SLE
george88gta
george88gta
Loc: new york
Reg: 04-23-03
08-30-19 04:38 AM - Post#2774457
Yes, I am of the same opinion, defective regulator. Pump was replaced. I was kinda hoping for a little less work, this regulator isnt an easy swap like my TPI or LS engines. Thanks for the response.
Edited by george88gta on 08-30-19 04:38 AM. Reason for edit: No reason given.
08-30-19 07:58 PM - Post#2774532
I’ve replaced a few fuel pumps just to replace a bad fuel regulator. I tell friends for labor costs, it’s the same either way. Cheap fuel pumps just don’t last.
george88gta
george88gta
Loc: new york
Reg: 04-23-03
08-31-19 04:40 AM - Post#2774540
We went with an Airtex pump. The original pump was getting very noisy.
08-31-19 05:27 AM - Post#2774546
How's it running now?
george88gta
george88gta
Loc: new york
Reg: 04-23-03
08-31-19 10:31 AM - Post#2774566
OK, confusing reply on my part. When the pump was replaced, a while back, we installed an Airtex. Waiting for a regulator and setting aside some time to change it. Will post up results, but it will be a while before we can coordinate schedules.
george88gta
george88gta
Loc: new york
Reg: 04-23-03
09-06-19 03:43 PM - Post#2774958
Update, I kind of moved this to the Chevy High Performance forum. Please check there for new info. We started the process yesterday and are at the point where the fuel lines are all connected and the plan is to do a pressure test tomorrow before finishing the job. Fire department is on speed dial. Thanks for the help.
Execution time: 5.839 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:18 PM
