Username Post: reverse switch will not close circuit        (Topic#357828)
rebuildroger
Reg: 03-14-16
08-27-19 04:24 PM - Post#2774214
1998 c1500 2wd 4.3l 5 speed manual
reverse lights giving me grief
its seems that when the tranni is put into reverse...it is not making proper contact with the plunger on the reverse switch.
i removed the switch from the tranni...and installed it into the wiring harness..depressed the plunger and the lights work.
So i have power and continuity thru the switch.
Re-installed the switch into the tranni...turned key to run position...put tranni in reverse...set tester to tone...probed both sides of switch and can not get a tone. So i guess that when in reverse it is not making proper contact on the plunger and therefore is not closing the circuit.
the tranni is a getrag.... rpo mg5
Have not had any luck sourcing a diagram etc that shows how it makes contact with the plunger.
All help greatly appreciated
08-27-19 05:24 PM - Post#2774223
    In response to rebuildroger
Did it ever work? It may be the wrong switch. Rock Auto shows different length switches.
https://www.rockauto.com/en/catalog/chevrolet, 1998...
rebuildroger
Reg: 03-14-16
08-28-19 08:29 AM - Post#2774288
    In response to acardon
yes it worked in the past...have had truck since new. The switch it uses is the longer of the 2 made for that tranni.
my question is what actuates the switch ...a bar...a plunger...???
can not find any info that shows it
Execution time: 0.103 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:19 AM
