Username Post: 1950 Chevy Delux        (Topic#357797)
black95jimmy
black95jimmy
Loc: Venice, FL
Reg: 01-05-02
08-26-19 06:09 AM - Post#2774054
Stock except for HEI distributor, ran fine last year, now hardley any vacuum, idle screws have no effect, turning distributor has no effect either? Put car in gear, runs awful, no power.
Huge vacuum leak?
82 Monte Carlo SC, 355 w/Vortec heads, roller rockers, 625 Demon Carb, TRUE DUALS.
2009 Sub.5.3L LTZ 30 Gallons of gas @ $2.28/gal. bla bla bla.
2blu52
"19th Year" Silver Supporting Member
2blu52
Reg: 03-12-02
08-26-19 06:32 AM - Post#2774056
    In response to black95jimmy
First thing is fresh fuel!If it ran fine last year and you have just started it for the first time since them there should be no changes mechanically so the first thing I would check would be hoses that may have cracked during the down time.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
black95jimmy
black95jimmy
Loc: Venice, FL
Reg: 01-05-02
08-26-19 07:53 AM - Post#2774061
    In response to 2blu52
Put a new fuel pump on yesterday, only had 2 psig. Fresh gas too. Starts fine, just will not run under a load?
2blu52
2blu52
Reg: 03-12-02
08-26-19 11:31 AM - Post#2774083
well you have fuel, and there fore must have spark and air or it would not run at all, so I would be looking at how the fuel is getting or not getting to the cylinders. Time for a quick check of vacuum leaks and then barring any problems a carb tear down and cleaning.
THOMAS JEFFERSON
black95jimmy
black95jimmy
Loc: Venice, FL
Reg: 01-05-02
08-26-19 01:20 PM - Post#2774089
Ok, will check for vacuum leaks, kinda what I thought originally, thx for the help, BTW, my friends car, not mine.
Ron of Chicago
Reg: 02-04-14
08-26-19 03:05 PM - Post#2774094
Maybe a critter crawled in the tailpipe and built a nest.Hence a restriction.
2blu52
2blu52
Reg: 03-12-02
08-26-19 06:01 PM - Post#2774106
    In response to Ron of Chicago
An excellent thought.
THOMAS JEFFERSON
black95jimmy
black95jimmy
Loc: Venice, FL
Reg: 01-05-02
08-27-19 06:46 AM - Post#2774163
WOW, good thought
black95jimmy
black95jimmy
Loc: Venice, FL
Reg: 01-05-02
09-06-19 08:33 AM - Post#2774940
Swapped out distributor for PERTRONIX unit, starts and runs good in second-third gear, bogs and bucks in first. Has good vacuum????????
2blu52
2blu52
Reg: 03-12-02
09-07-19 02:44 PM - Post#2775014
Back to the carb! and recheck timing and vacuum advance..
THOMAS JEFFERSON
Edited by 2blu52 on 09-07-19 02:46 PM. Reason for edit: No reason given.
black95jimmy
black95jimmy
Loc: Venice, FL
Reg: 01-05-02
09-19-19 12:16 PM - Post#2775888
Was carb, it was a rebuilt unit? New carb on it now, idles perfect, runs strong. Thanks for all the help.
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
09-22-19 03:40 AM - Post#2776108
Glad you solved your problem.
Dean50
drew1987
drew1987
Loc: Rochester, New York
Reg: 02-23-14
09-22-19 06:16 AM - Post#2776117
To me that almost sounds like a needle/seat or other flooding issue.. once it "got going" it was able to make use of the extra gas that it couldn't make use of at idle/low speeds. The carter and Rochester for these are easy to rebuilt; hang on to it as a spare and rebuild it your self or for your friend and try it out (obviously not in the presence of another issue or it could become unnecessarily complicated). I just went through this with my car
Glad you (and your friend) are up and running
Andrew D. Carapella (Drew)
'50 Deluxe 4dr v8 auto
Member:
Rochester Street Rods - Est. 1970
http://www.rochesterstreetrods.org
CrossMembers Car Club - Hebrews 12:2
http://www.crossmemberscc.com
Execution time: 0.068 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:33 AM
