Username Post: anti-lock lite on?        (Topic#357794)
rod
Member #248 Senior Member
Loc: kingman,az
Reg: 04-29-00
08-25-19 02:59 PM - Post#2774027
I just bought a 2001 Chevy P3500 class C motor home. I drove it 145 miles home. no problem. I changed oil Friday and when I started it, the lite came on. there are only wires to the front brakes. and I can see no mouse damage. this MH only has 45 thou. on the clock, and I can just see the pads, there is a lot there. the ABS fuse is good.
so 3 ?s. what might have cause this,can the lite be turned off [like check engine lite gets turned off] and what happens if I just go ahead and drive it?
thanks Rod in AZ
george88gta
george88gta
Loc: new york
Reg: 04-23-03
08-25-19 03:08 PM - Post#2774028
    In response to rod
Probably going to need someone scan it. Could be a defective wheel sensor or it could be in the ABS module itself. If they have the better scanner, they could do an ABS bleed for you. Best guess is that it won't cause a problem, you just won't have ABS. Here in NY, it will pass state inspection with the light on.
rod
Loc: kingman,az
Reg: 04-29-00
08-25-19 03:18 PM - Post#2774031
    In response to george88gta
thanks. leaving for vacation and may not have time to have it serviced. guess I will do a Penny [from Big Bang] and put some black electrical tape over the light!
Rod in AZ
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
08-26-19 07:08 PM - Post#2774119
    In response to rod
Lol.
Check the battery terminals. MAke sure they are clean and tight.
Get the code pulled, should explain it all.
Happy Motoring
Old School GM fan FOREVER
Execution time: 0.075 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:48 AM
