Username Post: 2010 Silverado        (Topic#357747)
Oklahoma2k
Reg: 08-08-12
08-21-19 04:36 AM - Post#2773737
Hi Gang, finally got tired of crank windows and manual door locks on my 2000 Silverado work truck. Yesterday the 2000 turned into a 2010 with allot more creature comforts. One owner well taken care of 5.3 with a little over 150,000.
Still learning what all the original owner has done to the truck. I know the Active fuel management has been disabled and he obviously installed some after market high flow exhaust, it's a little loud but sounds kinda cool.
MY 2000 had 260,000 on the clock and still ran and drove like new. Any thing I should be on the lookout for with the 2010?
Senior Moderator
08-21-19 06:21 AM - Post#2773749
    In response to Oklahoma2k
If you're using it as a work truck, try to be gentle on the door handles, particularly the interior ones. They're attached to the door panel itself instead of the inner door skin; they break somewhat easily and the dealer solution is you replace the door panel. There's an aftermarket kit that lets you glue/screw a replacement handle to the panel; much cheaper solution, looks like it may hold up fine.
Some may argue it but the disabled AFM is a good thing. Keep up with your oil changes and use the GM recommended spec and weight of oil. Listen for any lifter ticking, knocking, squeaking. Had 'em go bad twice in my 2009 6.0 work truck but it was indeed worked hard.
Oklahoma2k
Reg: 08-08-12
08-21-19 08:25 AM - Post#2773759
    In response to someotherguy
Thanks for the info. Looking under the hood I found a big black hose that says K&N, looked under the truck and not one spec of rust on anything, looks like it has been undercoated. This truck was well taken care of by the original owner and I plan to follow with the same.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
08-21-19 04:13 PM - Post#2773780
I say follow what it was maintained like.
Sounds like the PO was on the right direction.
Just a FYI things got really cheap.
Keep an eye on the transmission. HAve seen my share of torque converters that give out around that mileage.
Good luck with the upgrade
Old School GM fan FOREVER
Oklahoma2k
Reg: 08-08-12
11-27-19 07:33 AM - Post#2781054
    In response to rockfangd
Transmission was one of my concerns with the mileage, no way to really prove it but my transmission guy says it has probably already been rebuilt or replaced. Fluid looks like new, it shifts and acts perfect.
I was wrong about the AFM being disabled, salesman lied Ha... Bought a used but unmarried Diablo i2 tuner and installed the caned 87 tune with AFM disabled. Runs much better and throttle response is allot better.
I have put a couple thousand on it and yesterday checked the engine oil. Was still right at the full mark which made me happy. Have seen posts where these trucks can use a 1/2 quart in 2500 miles. Am hoping I got a good one, you just never know.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
11-27-19 02:27 PM - Post#2781098
that is not bad at all if it does consume that much.
Execution time: 0.133 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:05 PM
