Username Post: TH400 whine        (Topic#357746)
dav56
dav56
Loc: sumner,washington
Reg: 01-13-03
08-21-19 04:04 AM - Post#2773735
I have a TCI th400. 7,200 miles on it. It whines in 1st gear . Sounds like a gear drive. Then clunks when shifting into 2nd at low speed. 2-3 shifts fine,no noise. No noticeable noise driving at speed. Anyone know what could be causing this?
http://www.cardomain.com/ride/503656
08-21-19 03:57 PM - Post#2773778
    In response to dav56
Usually caused by the bearings in the planetary assy.
56sedandelivery
Gold Supporting Member
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
08-21-19 08:37 PM - Post#2773798
How about reverse gear, does it whine also? Sounds like the rear planetary assembly pinions/sun gear/wear bushings are shot; same as my DD truck that I have to swap the trans out on. I am Butch/56sedandelivery.
dav56
dav56
Reg: 01-13-03
08-23-19 05:17 AM - Post#2773867
Does that mean I would have to replace the bearings. Or the complete planetary assembly? I never noticed the noise in reverse. It does clunk a little going into reverse?
Edited by dav56 on 08-23-19 05:19 AM. Reason for edit: No reason given.
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
08-23-19 08:38 AM - Post#2773880
IF it's the rear planetary assembly, it should be noisy in first AND reverse, as that planetary provides the low gear reduction to those gears; a one time clunking, when going into reverse, sounds more like something more rear end tolerance or universal joint related. The planetary will need to be rebuilt or replaced; easier to just replace. The bigger concern are the metallic particles from wear, and getting circulated throughout the trans/converter/cooler. Complete rebuild and flush, and I don't look forward to doing that in this heat we're having here. I may just let a friends son, who has an automotive shop, just do the R and R with my spare trans, and do a cooler flush. I am Butch/56sedandelivery.
Execution time: 0.177 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:06 AM
