Username Post: Replace my 30 chevy engine        (Topic#357734)
mikenath
Reg: 06-16-19
08-19-19 11:01 PM - Post#2773622
Can anyone help to tell me if I can put a 38 chevy inline 6 cyl. complete with Trans. In a 30 chevy car. If so do I need to change the motor mounts or can I use the 30 motor mounts? Thank you for all your help.
Rustchips
Rustchips
Loc: DFW Texas
Reg: 02-24-05
08-20-19 11:40 AM - Post#2773679
    In response to mikenath
There is more to it then changing motor mounts.
The 216 engine is shorter then the '30. I did this years ago. I had to make a extension plate for the front crossmember for the front mount to rest on. This was using 216 engine mounts. I found a rear cross member that a fellow chat member was kind enough to remove and send me. Removed the '30 rear crossmember and drilled the frame to install the 216 crossmember. It is not easy but can be done
Cleon
1928 Chevy Coupe
1955 Chevy Bel Air HTP
1970 El Camino
1990 F##d Mustang Convertible
mikenath
Reg: 06-16-19
08-21-19 02:48 AM - Post#2773732
    In response to Rustchips
Thank you so much for the info
Execution time: 0.192 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:55 AM
