Username Post: 1960 horn button confusion        (Topic#357691)
andy k
Loc: Nor Cal
Reg: 08-12-19
08-17-19 08:17 AM - Post#2773381
Hi all, I have a '60 Belair 4 dr sedan with the small horn button, no chrome half-ring, and I can't figure out what's missing to hold that horn button onto the steering wheel. Not the contact parts, but the receiver cup. It seemed like only a 1/8" space around, so I bought a rubber piece off eBay saying it was for '60-'68. one eBay seller was right, it's not for this car. the chrome half-ring on my '60 El C. bolts down to the contact piece and then to the wheel. If someone could shoot me a photo of both sides once they pull the horn button off a similar model, I'd sure appreciate it. My car came just a bare wheel in a recent purchase. Thanks rcr3 for the tip where to post! I have photos on my email if needed. I called a page of classified ad phone #s from a 1991 Late Great Chevys, no help. Thanks for anything, my memory broke down-andy k
I forgot to say neither assembly manual nor service had much- the assembly man. was kind of mis-printy in the illustration. It's in the steering wheel section, after st. column, before wheels/tires. I even got a CD Rom of all part numbers-no diagram for those parts, section 6.513...I need to flag down a car or two here in my town.
Edited by andy k on 08-17-19 09:54 PM. Reason for edit: No reason given.
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
08-17-19 09:53 AM - Post#2773390
    In response to andy k
You might find drawings in the assembly manual or the shop manual supplement for the 60?
Member #2194
Edited by DonSSDD on 08-17-19 09:54 AM. Reason for edit: No reason given.
PLS
PLS
Loc: Smyrna, Georgia
Reg: 06-07-12
08-17-19 04:28 PM - Post#2773420
You might give Danny a call, he may be able to help you.... https://www.southeastchevyparts.com/ let us know how you come out. A big welcome to Chevytalk where you can usually get an answer to your 60 questions pretty quick. Don I checked my 60 assembly manual and the shop manual but couldn’t find anything concerning the horn button. Lamar
Lamar
My ’60 Chevy history video: https://www.youtube.com/watch?v=kuLdKs2Gp5k
1belair1954
Reg: 12-24-12
08-19-19 12:36 AM - Post#2773532
Hi checkout my post on repairing a cracked steering wheel you will see the assembly that holds the horn together on my 1960 el camino .
Sorry about the size of the photos you need to scroll to the right you will see a part that has 9 fingers sticking up this holds the horn button on
on my el camino i would say it would be the same on biscaynes and belairs
andy k
Loc: Nor Cal
Reg: 08-12-19
02-14-21 07:28 PM - Post#2814274
    In response to 1belair1954
Thanks 1belair1954!! No one else could help and no one has this part. Eckler's never heard of it. Anyway I'm going with deluxe non-Impala horn ring which I've always liked the looks of on my El C. long delay as I've been working on the floors and dash. much appreciation- I wonder if I could make that part? must be spring steel. I used a P.O.R. epoxy on my cracked wheel, high-fill primer and body shop-made -into-a -spraycan paint then clear, and it looks pretty good. a couple of fine files got it close before sanding and I'm happy with it. Cheers, Andy ('60 BelAir, red outside, gray inside)
1belair1954
Reg: 12-24-12
02-23-21 12:31 AM - Post#2814920
Hi probably would not be hard to make but not sure if you can temper or quench the metal as it is a type of spring steel.
The horn buttons come up on ebay occasionally you might get lucky with the retainer.
I cannot sell you mine haha my steering wheel had many cracks in it i thought I would give it a go fixing it its easier than I thought just alot of sanding but the epoxy seems to stick well.
If anybody has cracked steering wheel grind out the cracks and use JB weld. Or other epoxy
Execution time: 0.105 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:58 PM
