Username Post: HEI swap help        (Topic#357688)
Squire_impala
Reg: 05-27-18
08-17-19 06:37 AM - Post#2773365
My 65 has a 327 with stock points ignition. I switched it over to HEI. Anyone who has done this swap, when you ran your new 12g wire. Where did you hook it up too? Some forums I checked they say hook it to the fuse box others say hook it right to the key switch. Where is the best place to hook for a good 12volt source?
Chris
08-17-19 07:03 PM - Post#2773435
    In response to Squire_impala
You can do either. If you have a position in the fuse box open that has power when the key is on you can use that or you can replace the wire that runs from the ignition switch to the R terminal on the starter and run it directly to the distributor. You should use a 12 gauge wire either way.
1957 Cameo Carrier
Aaronbang
Loc: Visalia,CA
Reg: 08-13-14
08-20-19 04:15 PM - Post#2773696
You actually need to get power from a source that is hot with the key in the run position and also from the R terminal on the starter, when you turn the key to the start position it cuts power to everything except the starter solenoid, this is why they provide the R terminal on the starter.
If a hammer can't fix it, it really IS broken
59fins
Member #212 "19th Year" Gold Supporting Member
59fins
Loc: Surprise Az USA
Reg: 04-07-00
08-21-19 08:45 AM - Post#2773754
Chris
"I switched it over to HEI"
What is your definition of HEI? monster size distributor? etc.
Pertronics?
AAW's HEI conversion? stock looking or race?
How do you drive your car I guess would be the simple question?
Bill H.
67 Impala SS
Squire_impala
Reg: 05-27-18
08-26-19 08:32 AM - Post#2774066
    In response to 59fins
I installed a MSD street fire distributer with the coil built into the cap. I use it as as my daily driver back and forth from work as well as taking it to car shows. Its by no means a race car and I don't intend it to be. I hooked it up to my fuse panel with a 12gauge wire and it runs fine. Which has me confused, if it kills all power except the R terminal shouldn't it not start at all?
Execution time: 0.222 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:56 AM
