Username Post: 1950 Fleetline Steering Wheel Help        (Topic#357660)
nicke
nicke
Loc: Spokane, Washington
Reg: 01-06-12
08-15-19 11:44 AM - Post#2773249
Hey Guys,
I'm helping my dad finish up his 1950 fleetline. He'd like to put a 1959 impala steering wheel in it. Is there an adapter available to adapt the impala wheel to the stock fleetline column?
-Nick
My 65' Impala SS LS Swap
My Classic Car Videos
6.2L LS ,4L80E, 3.73 gears, disc brakes
53sd
Reg: 12-08-08
08-15-19 07:46 PM - Post#2773280
    In response to nicke
I'm betting the Impala will fit with no problem.
The spline is the same, the transition to the signal housing probably the same also.
nicke
nicke
Reg: 01-06-12
08-16-19 04:03 PM - Post#2773330
    In response to 53sd
Interesting. I'll pull the old wheel to see if that's the case.
Thank you!!!
-Nick
nicke
nicke
Reg: 01-06-12
08-19-19 11:41 AM - Post#2773572
Those of you who are running different steering wheels, what type of collar are you using to adapt the skinny stock column to a larger diameter than stock steering wheel to make it look right? Anything?
Thanks again!
-Nick
Execution time: 0.123 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:58 AM
