Username Post: AC HOSES        (Topic#357646)
6T5
"2nd Year Gold Supporting Member
6T5
Loc: Asheville, NC
Reg: 07-22-17
08-13-19 02:58 PM - Post#2773156
I have blown out an old AC hose coming from the expansion valve to the dryer. These are the hoses that has the clamp with the hook end to secure. Any idea where to buy and replace both of these old hoses? Thanks...
...Ed
1965 Impala SS
Tiny1000
Tiny1000
Reg: 01-20-15
08-14-19 05:05 AM - Post#2773192
    In response to 6T5
I purchased my hoses from Classic Auto Air 813-259-7688 a little pricey around $50 per hose
junky
Loc: Northeast CT
Reg: 06-27-10
08-14-19 09:44 AM - Post#2773213
    In response to 6T5
I just rehosed my 1962 BelAir, and it was amazingly easy once you get the old hoses off. To remove the old hose, you have to cut the rubber off a little at a time till you are down to the cord. Then you can carefully score the cord and pull the hose off. You have to be careful not to damage the aluminum barbed fitting, because if you do, it can cause you leaks. The new hose is what is called barrier hose, and it keeps the freon contained better than the old hoses. I would suggest that you replace all hoses, and the drier. Remove the compressor, and drain the oil and add new oil. I bought the AC Delco mineral oil from Amazon, about $15 per quart. I bought my all my hoses on eBay in 25' lengths. My '62 uses 1/2", 3/4", and 13/16". I added 11 ounces of oil to the compressor, and evacuated the system for 48 hours, and then closed the valves on the gauges, and left it for 12 hours, to verify that it held vacuum. Then I pressurized it with nitrogen and checked it again. I found that it was leaking down a little. Checked and found that it was the front seal on the compressor. This leak was caused because there was no oil in this seal, so I went ahead and charged the system. Once the compressor was working, the leak went away. I am not a believer in using R134 in place of R12 for various reasons that I don't see a need to get into. If you would like to discuss this further, I will be happy to give you my experience, just send me a PM. Junk
Verne_Frantz
Member #574 "61-64 Subject Matter Expert"
Verne_Frantz
Loc: Hightstown,NJ USA
Reg: 08-22-00
08-14-19 08:10 PM - Post#2773236
    In response to junky
Junky,
Where did you find your new receiver/dryer? It looks correct in the photos.
Verne
6T5
6T5
Loc: Asheville, NC
Reg: 07-22-17
08-16-19 09:50 AM - Post#2773304
    In response to Tiny1000
Do you remember the three ID sizes of your hoses? I might as well replace all of them...
...Ed
1965 Impala SS
6T5
6T5
Loc: Asheville, NC
Reg: 07-22-17
08-16-19 03:05 PM - Post#2773328
    In response to 6T5
Just wondering if anybody could get the A/C hose ID's from these numbers in the assembly manual.
#3816436 hose from muffler to condenser
#3864395 hose from txv to drier
#3793824 hose from stv to compressor
...Ed
1965 Impala SS
100 CHEVY
Deceased Member RIP
100 CHEVY
Loc: Helena,Missippi,U.S.A.
Reg: 12-09-04
08-17-19 07:46 AM - Post#2773371
    In response to 6T5
The hose sizes I used on my 65 are---
1/2"(13 mm)
5/8"(16 mm)
13/32"(10 mm)
These are the newer barrier hoses for use with R-134A,although I'm using R-12 in mine.
My dryer came from a parts car that had a sealed a/c system in it,so I re-used it.
Mike.
Edited by 100 CHEVY on 08-20-19 03:42 PM. Reason for edit: No reason given.
6T5
6T5
Loc: Asheville, NC
Reg: 07-22-17
08-17-19 12:29 PM - Post#2773397
    In response to 100 CHEVY
Exactly what I was looking for, thanks 100chevy...
...Ed
1965 Impala SS
100 CHEVY
Deceased Member RIP
100 CHEVY
Reg: 12-09-04
08-18-19 06:06 AM - Post#2773458
    In response to 6T5
You're welcome!
Mike.
Execution time: 0.073 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:17 AM
