Username Post: 265 v8 with th350 vacuum help        (Topic#357632)
captainjack1967
Reg: 08-11-19
08-12-19 02:15 PM - Post#2773062
Hello new to the group i have a 55 bel air with stock 265 ci and a th350. The trans was not hooked up and i am having trouble finding a vacuum port to connect the trans. The intake does not have any ports that i can see and the 2 barrel carb only has the one on the back which is being used and goes to the back of the engine. Any help is appreciated and thank you guys.
08-12-19 04:18 PM - Post#2773075
    In response to captainjack1967
If that one line is manifold vacuum, you could tee off that for the trans, but where does that line go?
captainjack1967
Reg: 08-11-19
08-12-19 05:30 PM - Post#2773087
It goes from the back of the carb to the back of the engine. Can i t it off so it can go to the trans as well ? Ill post a picture in a bit if i can
YOUNG57
Loc: Tennessee
Reg: 12-06-10
08-12-19 06:23 PM - Post#2773090
I think you need to find out where the existing vacuum line goes. What size is it, 3/16” or 3/8”? If it is 3/8” maybe the PO converted the road draft to a PCV.
Is the distributor vacuum advance still a hard steel line from the front of the carb.
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
08-12-19 11:20 PM - Post#2773104
    In response to YOUNG57
Just curious; do you have the starter motor adpter ring sold by several of the Tri-Five vendors? 55-56 265's do not have a starter motor mounting "pad" on the block, so require the adapter ring for a starter motor with a newer, aluminum case automatic transmission. Many guys do not know this. I am Butch/56sedandelivery.
Edited by 56sedandelivery on 08-12-19 11:22 PM. Reason for edit: No reason given.
f.i.57chevynut
f.i.57chevynut
Loc: Granada Hills, CA
Reg: 03-04-09
09-12-19 09:52 PM - Post#2775435
You can use a turboglide starter. They bolt to the 57 block.
Tom Ordway tom@57chevys.com If you don't drive it, why have it?
http://www.americantorque.com/page/0/139/
Execution time: 0.106 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:40 PM
