Username Post: Intake Vacuum leaks?        (Topic#357630)
Go18Go
Reg: 08-12-19
08-12-19 10:19 AM - Post#2773039
while tuning up my electric choke i noticed a sucking noise on the intake manifold. Its coming from four holes. Put you finger on them and its sucking, all four hole. Quick google and these are the four bolt holes on a edelbrock performer RPM 2 intake #75621. Heads are patriot 320CC both have rectangular intake ports. These four bolts are specified in manual as hand tighten only.
Mine have no bolts and you can see the gasket covering the holes between block and manifold. Never was a bolt in any of these four holes.
The question is this, is there any reason this would have been done intentionally? The car runs great, its dyno'd at 638 hp 652 torque. When i plug all four holes the idle drops way down and car barely wants to keep idling.
Manifold IMage
Edited by Go18Go on 08-12-19 10:48 AM. Reason for edit: No reason given.
Mel Foye
Mel Foye
Reg: 09-29-00
08-12-19 01:15 PM - Post#2773048
    In response to Go18Go
Have never worked with a set up like you have but here goes. The bolts you have look far apart to me so I think that the intake holes are meant to have a bolt there.
If you are lucky all you need is a different intake gasket set and four bolts. Otherwise there is a mismatch with the manifold and the heads. With air coming in after the carb and it idles good, likely you are on the rich side of settings. Let us know the outcome. Mel
IgnitionMan
Reg: 04-15-05
08-12-19 01:33 PM - Post#2773050
I have never seen a big block head that did not use these hold down holes, and I would have added them in the process.
Yes, there is a vacuum leak, could be from two different places, one more serious than the other, both important.
The secondary leak, air in the engine chamber the PC valve controls.
Important, air/fuel mixture leakage from the tops of the inlet passages, because the heads and manifold do not have the bolt holes working.
If it were me, at this point, I would use UNLIT, UNLIT, UNLIT propane flowed over the leakage areas, to confirm just a mixture vacuum leak. With propane, no residue, nothing but rpm's going up, and the smell of burned propane where the leak(s) are.
As I said, me, I would have added the holes/threaded areas.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
08-12-19 02:25 PM - Post#2773057
    In response to IgnitionMan
yes you need to replace the intake gasket and install the correct length 3/8"/16 tpi bolts in the 4 holes
then re-adjust the carb to get the engine idle correct
http://www.gtsparkplugs.com/BBC-Intake-Torque-Seq u...
Edited by grumpyvette on 08-12-19 02:28 PM. Reason for edit: No reason given.
Execution time: 4.371 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:14 PM
