Username Post: Window Channels and Belt Weatherstrip        (Topic#357619)
jvahila
Loc: Canton Ohio
Reg: 11-07-17
08-12-19 07:26 AM - Post#2773014
Good Day All
Does anyone have experience, knowledge or advise on installing the window channels and belt weatherstrips on a 1954 Bel-Air? is the any tricks or special clips I need to hold in the Channels etc...
when I purchased to car most of all that was missing. but he gave me new channels and weatherstrips.
Thank You
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
08-12-19 10:25 AM - Post#2773040
    In response to jvahila
I suppose it would matter depending on what model of Belair you are taking about. There were clips originally on most models...not sure how it was done on the Sport Coupe / Hardtop. If you just have the bare channel, there are guys here who were in your same situation...they can chime in.
1951 Fleetline Preservation
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
08-12-19 11:52 AM - Post#2773044
I recently went through that myself. The overall recommendation was that this should be glued in place, instead of using the clips. I did that and it worked pretty well. I used black RTV.
I haven't tackled the belt weatherstrips yet.
Scott Acton
1954 Chevy Bel Air 2-door
http://www.my54chevy.com
Edited by dsacton on 08-12-19 11:54 AM. Reason for edit: No reason given.
19Chevy50
19Chevy50
Loc: Wichita, KS
Reg: 06-21-19
08-12-19 01:06 PM - Post#2773047
    In response to dsacton
I completed this last spring in my 50 Chevy and used the black RTV for channels. It worked out very well.
50hotrod
50hotrod
Reg: 07-25-11
08-12-19 04:53 PM - Post#2773073
    In response to 19Chevy50
I used clear RTV. The trick is getting them bent correctly so they practically sit in place without anything holding them.
1950 CHEVY 2 DOOR 327 TRI POWER FENDERWELL HEADERS HEIDT FRONT SUSPENSION 700R4 TRANS 411 REAR
08-12-19 06:23 PM - Post#2773085
    In response to 50hotrod
We always used 3M yellow Weatherstrip adhesive in the glass shop I worked in back in the 1970's. However, RTV may be just as good. Maybe better. Back then, and I don't know if this is still true, the 3M yellow was better than the 3M black.
rawaag
rawaag
Loc: Williamsburg Virginia
Reg: 06-12-09
08-26-19 08:23 AM - Post#2774065
I tried several things when installing mine, but nothing seemed like it would hold up overtime. I finally came up with a solution that has held up over the past 8 years without any problems. I used small pop-rivets and touched up the heads with a little black paint. You'll find it's easier than the other methods. Good luck!
Ralph
Execution time: 0.069 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:14 AM
