Username Post: Anyone have a diagram for brake lines for a '67 drums only        (Topic#357610)
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
08-11-19 04:47 PM - Post#2772983
Hey guys I have a '60 that I'm putting a dual master cylinder just drum brakes only. I need to put new brake lines and need a diagram for a '67.
sz0k30
sz0k30
Loc: Oakland Co., Michigan
Reg: 10-12-08
08-12-19 06:07 AM - Post#2773007
    In response to Eth727
Your post doesn't make any sense.
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
08-12-19 09:04 AM - Post#2773025
    In response to sz0k30
I'm putting a '67 dual master cylinder with drum brakes on my '60. I'd like to put new brake lines just how it was for a '67 not 60. I just want to see if it's routed the same way. Someone told me 67 brake lines were routed a different way than a 60.
100 CHEVY
Deceased Member RIP
100 CHEVY
Loc: Helena,Missippi,U.S.A.
Reg: 12-09-04
08-12-19 10:15 AM - Post#2773037
Since your 60 has an x-frame and a 67 has an H- frame,it's going to be difficult to use those brake lines.You will need to re-bend the lines to fit.
The 67 lines run along the inside of the drivers side frame rail.
At the rear,the line turns out on the swing arm cross member to the distribution block on the right side of the rear axle.
At the front,the line comes up the frame to the frame mounted distribution block just behind the a-arm.
The 2 lines from the master go to the block on the frame.
The front wheel lines run from the block to the left front wheel and across the engine crossmember to the right front wheel.
I believe there's a drawing in the support section under suspension.Never mind,I couldn't find anything there!
Mike.
Edited by 100 CHEVY on 08-12-19 10:32 AM. Reason for edit: No reason given.
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
08-12-19 04:19 PM - Post#2773069
    In response to 100 CHEVY
Yeah I will be making my own custom lines especially for the rear brake system. I didn't know about the H-frame until now. It might be easier to follow my original line with longer one.
100 CHEVY
Deceased Member RIP
100 CHEVY
Reg: 12-09-04
08-12-19 04:34 PM - Post#2773071
For what it's worth,I bought my 67 power brake master cylinder at O'Reiley's.
I took the distribution block off my 67 Impala parts car.
I bought the new lines from In-Line tube along with a few extra fittings.
All this was to change my 65 to the dual master system.
Mike.
Execution time: 0.141 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:17 PM
