Username Post: Ignition/crank power on/off switch        (Topic#357609)
Senior Chevytalk Moderator
08-11-19 11:50 AM - Post#2772968
A '95 GMC Jimmy has a short in the key switch wiring. The key cylinder has been replaced. With a slight movement, key out, it will crank until the battery is dead. It won't start because fuel and ignition are off (or at least one of them). I suggested installing a push button to cut crank power. However, I'm not sure which power to cut out and switch activate. The steering column must have power on all the time if key is removed and it will crank on it's own. I have a set of '96 factory manuals. Wiring should be the same for a '95. At least close enough since it was a transition year to MPFI in '96.
Does anyone have a suggestion? A color power on/off switch is on order. After turning off, switch will be turned off to cut power. The switch will be lighted with power on. In the run position, the starter has not engaged. It only engages in off and key out/in position.
08-11-19 12:32 PM - Post#2772969
Purple wire powers the starter solenoid. The key has a double D connection to the switch, it could be 180 degrees out of phase.
08-11-19 01:48 PM - Post#2772975
    In response to acardon
The problem started before a key cylinder swap. I think it can only go in one way. I remember replacing the turn level switch. The block module wiring was disconnected for replacement. For more than a year it didn't do it. However, after selling it to my friend, he had it parked for several months. When he started to drive it daily or often, that's when the problem started.
So either the red or purple wire would be good to splice into for a switch?
Could the ignition lock housing be worn out from use?
Edited by gchemist on 08-11-19 01:51 PM. Reason for edit: No reason given.
65_Impala
Reg: 12-29-02
08-19-19 08:49 AM - Post#2773554
Isn't the switch and tumbler two different parts? It is on most GM's. Might need to change the switch.
Purple seems to be the color used for the solenoid wire on pretty much any GM.
08-20-19 05:33 AM - Post#2773640
    In response to 65_Impala
Do you mean "ignition lock housing "?
ACDELCO 26036474?
acardon has a harness pic. RockAuto has them. However there are different versions. I need more info to determine out 2-3 which one would swap.
65_Impala
Reg: 12-29-02
08-21-19 12:14 PM - Post#2773768
Not the mechanical parts. You said you replaced the key cylinder or tumblers, the mechanical part the key goes into. Yes, I think it's the switch in that harness picture posted.
Ignition switches have a single moving part actuated by the cylinder that either slides or rotates to the various electrical positions. This means if the electrical switch was good and being moved to the start position then the ignition power would also be on and it'd be starting. So, it's not likely the mechanical part is buggered up and moving the electrical switch to the crank position.
11-17-19 08:55 AM - Post#2780351
Follow up: no matter which fuse or relay I tried to bypass with a switch, it would still want to crank over. Final solution, cut the purple wire to the starter. I found a mid point to the wire over the engine harness. I cut it there to splice in a on/off switch. Similar size wire was run to and from the switch. The wire was routed over the engine and back down to the starter. Works great. No matter how much the key cylinder wiggles, it won't auto crank. To turn it on, the key is turned to the run position, the switch to on, and cranked to starting. Once it starts, the starter switch is moved to the off position. Going on two weeks without a problem. Since the starter was toast too, it was replaced with a smaller gear reduction starter. It costs $112 at local shop. It cranks over hard and fast. The owner is happy to be driving the old Jimmy again.
Execution time: 0.081 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:15 AM
