Username Post: 1950 3100 brake options        (Topic#357603)
baehrelw
Loc: west michigan
Reg: 12-16-15
08-10-19 07:13 PM - Post#2772927
I have a truck that I am keeping original. It has the Huck brakes in pretty good shape. Stopping power is not up to the needs of today. I have installed a dual master cylinder which is working fine, but doesn't really improve the stopping capability What are the options to keep the original wheels and significantly improve stopping capability?
Mick53
Mick53
Loc: Northern Indiana
Reg: 04-02-16
08-10-19 09:31 PM - Post#2772934
    In response to baehrelw
I would suggest a minimum of front disk brakes. There are some reasonably priced bolt up kits out there.
Mike JW
Mike JW
Loc: Arroyo Grande, CA
Reg: 01-19-06
08-12-19 01:31 PM - Post#2773049
    In response to Mick53
I agree with Mick, I know you said you wanted to keep it stock, but times, driving conditions have changed I put disc's on my 51 don't regret it for a minute. Big help.
baehrelw
Loc: west michigan
Reg: 12-16-15
08-12-19 05:58 PM - Post#2773080
    In response to Mike JW
were you able to keep your original wheels?
Mike JW
Mike JW
Reg: 01-19-06
08-13-19 11:56 AM - Post#2773140
I'm running centerline wheels on mine and was before I put the disc on. So never tryed it.
Mick53
Mick53
Reg: 04-02-16
08-13-19 09:00 PM - Post#2773182
Yes depending on what kit you buy. I have to run 17" wheels minimum but I'm running 13" disk.
CSM
CSM
Loc: Lexington, SC
Reg: 05-07-19
08-28-19 03:22 AM - Post#2774260
I have a 49 with 11in disc and wildwood 4 piston calipers however, I also run Foose custom wheels so be careful on the wheels you choose as the custom will not work with larger calipers. I recommend a 4 piston caliper on those new disc for slowing the lead sled down a bit.
Mick53
Mick53
Reg: 04-02-16
08-30-19 09:08 PM - Post#2774535
    In response to CSM
I'm running Wilwood also. 13" disk 4 piston rear and 6 piston front. Nickle plated. They were pricey and I had to have custom spindles made.
Attachment: Frankland_rear_end.jpg (30.41 KB) 23 View(s)
Execution time: 0.081 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:51 AM
