Username Post: regular or oil bath air cleaner?        (Topic#357601)
Bruza
Loc: Gisborne
Reg: 07-11-19
08-10-19 03:57 PM - Post#2772904
What type is the air filter on my car? I can only remove the base from which I have taken out the fiber matting and binned it. I can replace this easily enough. The rest of the unit does not appear to come apart and I am worried it contains debris from being stored poorly and this will suck into the carb and engine. I could cut the unit and convert it to paper element if worse came to worse. There is no room on top of my carb to fit a standard aftermarket air filter (58 Delray in-line 6)
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
08-10-19 07:21 PM - Post#2772928
    In response to Bruza
I'm guessing that this is the air filter you are describing:
Attachment: 49-52_dry_element_air_cleaner.jpg (401.02 KB) 26 View(s)
1951 Fleetline Preservation
junky
Loc: Northeast CT
Reg: 06-27-10
08-12-19 07:38 AM - Post#2773017
Submerge the old filter in solvent if it is just dirty. If there is rust, then submerge in solvent, let dry, and then submerge in a rust remover. Once you are satisfied that it is clean, follow instructions in the service manual to renew its filtering.
IgnitionMan
Reg: 04-15-05
08-12-19 01:36 PM - Post#2773051
I'd rather have an oil bath filter any day of the week.
2blu52
"19th Year" Silver Supporting Member
2blu52
Reg: 03-12-02
08-12-19 02:06 PM - Post#2773055
    In response to IgnitionMan
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
08-12-19 06:20 PM - Post#2773084
    In response to 2blu52
Ditto that. I've always run oil-bath air cleaners on all 6 of my stovebolts over the years.
bobt
Loc: colonial heights va
Reg: 06-28-14
08-13-19 01:48 AM - Post#2773106
This topic has came up many times before. I adapted my mesh screen filter to a paper filter and I am very happy with the results. bobt
Dave in VA
Dave in VA
Loc: SW Virginia, USA
Reg: 03-11-18
08-13-19 05:27 AM - Post#2773115
    In response to bobt
What paper filter did you use?
"Knowledge is Good" -- Emil Faber
U S Navy MM2 1970-75 USS Canisteo AO-99, USS Miller DE-1091 (The Champagne of Ships)
1950 Styleline Deluxe 2dr, mostly stock, driver quality...new to me 3/18
2017 Silverado LTZ 6.2
2020 Blazer Premier
Airlifter
Airlifter
Reg: 06-07-15
08-13-19 05:57 AM - Post#2773119
    In response to bobt
do you have a picture of that?
Thanks, Pete
1951 styline deluxe sport coupe w/'60 261 engine & 54 powerglide
tommy49
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
08-13-19 06:41 AM - Post#2773123
    In response to Dave in VA
I believe the replacement filter is the Fram CA-140 PL. Here's a crossreference chart:
https://www.airfilter-crossreference.com/convert/F...
Tommy
49 Deluxe Sport Coupe, 4.8/4L60E swap in progress, Blazer rear axle, 4 wheel power disc brakes.
Mikeky
Reg: 09-12-18
08-13-19 05:49 PM - Post#2773170
    In response to bobt
You say adapted. Did you have to make changes to the breather housing, or just remove the copper mesh screen and replace with the Fram filter?
bobt
Reg: 06-28-14
08-14-19 10:48 AM - Post#2773219
    In response to Mikeky
The only modification is to lengthen the stud that holds the top on as the new filter will be taller. I just sawed the old stud off and soldered a 1/4 x 20 bolt in its place. Before you close the hood for the first time, put a piece of clay or chewing gum on top of the new stud to make sure that you have clearance.
2D51STYDLX
2D51STYDLX
Loc: So. Prairie Washington
Reg: 03-03-11
08-15-19 12:16 PM - Post#2773253
    In response to RAM_51
This is what I did, the threaded rod was just long enough.
Attachment: EAEA282C-F429-4A91-A1A9-CBDDE4ACD0A5.jpeg (2.1 MB) 14 View(s)
Attachment: 8F61A23A-A210-4759-9743-839CB4ED7A79.jpeg (1.67 MB) 20 View(s)
Attachment: 3ED11A25-6F7B-47F0-B0E8-932C0FF1FDFB.jpeg (1.65 MB) 16 View(s)
Attachment: F8510C75-19F5-4F3A-A415-1A493C13CDB4.jpeg (1.78 MB) 12 View(s)
Roger
1951 2 door Deluxe Bone stock, well not quite, bucket seats.
Broken hearts and dirty windows
Make life difficult to see
Thats why last night and this morning
Always look the same to me
John Prine
Edited by 2D51STYDLX on 08-15-19 12:21 PM. Reason for edit: No reason given.
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
08-15-19 02:00 PM - Post#2773256
    In response to 2D51STYDLX
I had a tape measure like that, once.
52 Styleline Fourdoor 62 235 PG
RAM_51
RAM_51
Reg: 12-28-02
08-15-19 06:09 PM - Post#2773271
Back at the onset of this thread I was trying to determine from rosebush40 which air cleaner he was dealing with by his description and posted a photo of the dry / oil saturated element air filter hoping he would confirm. And indeed his thread title asks the question as to what filter he has. At this point in the thread however, 2DSTYDLX is dealing with and describing his conversion of an oil bath air cleaner. Just so everyone is on the same sheet of music.
junky
Loc: Northeast CT
Reg: 06-27-10
08-16-19 07:02 PM - Post#2773344
I believe that Rosebush has lost interest in this subject...
Posted the question 08-10-19 06:57 PM
Last Online: 08-10-19 06:57 PM
When people don't come back to read the help that they have been given, we are all wasting our typing skills and knowledge. Yes, he might have gotten sick, died, moved to another planet, but it happens all to often with "hit and run" posting by new people.
Mikeky
Reg: 09-12-18
08-19-19 05:42 PM - Post#2773606
    In response to junky
I often find these responses to different questions or problems interesting. They often offer me ideas for my ole '54 belair. Never think you are waisting your typing skills or knowledge. I, along with alot of others, appreciate your responses and knowledge!
Execution time: 0.112 seconds.   Total Queries: 19   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:56 AM
