Username Post: 454 into 57 chevy        (Topic#357581)
rockin rebel
rockin rebel
Loc: Langley, BC. Canada
Reg: 03-31-11
08-08-19 09:35 PM - Post#2772775
I know n a 55 you have to dimple the firewall.. how about putting a big block in a 1957 Chevy ???
niftyfive
Loc: Colorado
Reg: 02-07-05
08-09-19 05:00 AM - Post#2772789
    In response to rockin rebel
Same deal. A better alternative to BFH damage would be to section in a portion of a steel wheelbarrow.
NIFTYFIVE
55MAS
Loc: North Coast, USA
Reg: 12-19-01
08-11-19 06:01 AM - Post#2772948
    In response to niftyfive
OP has it right, some minor work using a hammer and dolly.
56sedandelivery
Gold Supporting Member
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
08-11-19 01:41 PM - Post#2772974
    In response to 55MAS
There is an entire forum related to "BBC into a Tri-Five", on that "other" 55-57 Chevrolet site. There are several different ways of doing the swap, depending on where you want to place the engine, and why. Stock bellhousing with a stick shift limits where it can go, unless several other things are also addressed. Stock location to 2-1/2 inches forward, just to give you an idea. The farther forward, the less firewall work is needed, but header to steering box, cross link in the steering, clutch linkage, all get affected with moving things forward. It seems, the best way to go about it, is to use the Williams setups; motor mounts, headers, etc, but probably the most costly as his parts are't "cheap". I did a BBC into a 56, model 150, Utility Sedan in about 1973, and it was the first time for something like it for me; it went off without a hitch. There was a fair amount of firewall massaging involved, and that was with stock valve covers, the oil pan just "touched" the cross link with far right/left turning of the steering wheel, and the number 5 header tube required just a little dimpling. I had to notch the cross-shaft Z-bar bracket attached to the bell-housing to clear the oil pressure sending unit, and "occasionally", the distributor cap would make contact with the firewall (small diameter distributors/caps were't around then). An automatic transmission would have been easier in several ways. That car eventually became my first dedicated drag car, a Pro Bracket car, and then sold to step up to my front engine dragster. I am Butch/56sedandelivery.
Execution time: 0.49 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:31 PM
