Username Post: Fuel tank sender strainer fell off. Now what?        (Topic#357560)
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
08-07-19 03:07 PM - Post#2772644
So I went to put in a brand new fuel tank sender. When I went to pull the old one out the fuel strainer fell off in the tank. I just went ahead and put the new sender. Now what should I do?Just leave it in there? Am I going to have problems later?
TYTILIDIE
TYTILIDIE
Loc: Colorado Springs
Reg: 10-21-15
08-07-19 06:09 PM - Post#2772654
    In response to Eth727
You'll be just fine. I opened a tank up once on a Typhoon and found 3. I was in the tank to install duel in-tank fuel pump set up, truck was running great. The customer said they owned the truck 5 years and they didn't replace the pump.
Me
Execution time: 0.085 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:46 AM
