Username Post: Tranny fluid leak        (Topic#357551)
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
08-06-19 03:17 PM - Post#2772562
I've got a little bit of tranny fluid leaking where the tranny meets the engine. Any recommendations on how to fix this?
ragtp66
Reg: 12-09-07
08-06-19 07:36 PM - Post#2772586
    In response to Eth727
If its the input shaft seal the only way to fix it is pull the trans. Check the easy stuff first. Filler tube seal, cooler lines, pull the hose off vacuum modulator and see if it has trans fluid in it.
Toys:
1987 Sea Ray Pachanga 22
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
08-08-19 04:46 AM - Post#2772675
If you can put up with the leak and it's small I'd let it go. Replacing the front seal will require removal of the transmission.
Vern
1953 Chevy Belair Sport Coupe - 355 Blueprint Engine, 700-R4, EZ Wire, Vintage Air, Ididit column, Cruise/Tilt, PS, 59 Corvette Steering Wheel, 4-Wheel Discs, Posies Rear Springs, Coker Radials, Nova 10-bolt, Mustang II, NCA Continental Kit.
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
08-08-19 02:34 PM - Post#2772723
It's a small leak. I can deal with it. I was thinking about trying that Lucas tranny stuff. It's supposed to help seal and make the tranny shift better.
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
08-09-19 03:57 AM - Post#2772781
I've never used it but it can't hurt anything to try.
Vern
Execution time: 0.139 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:42 PM
