Username Post: how many coats and how fast        (Topic#357548)
56chev66must
Reg: 04-07-04
08-06-19 01:31 PM - Post#2772547
Hi all,
I'm diving in and doing the $100 Rustoleum roller paint job on my Honda Civic. Got the car all sanded and prepped and ready for the first color coats. I'm using Rustoleum acrylic enamel (the usual hardware store quart cans) mixed about 50/50 with low-odor mineral spirits (totally pure MS was not available near me).
Here's where I'm stuck... I've read a lot of info about how to do the painting, and the many different websites all disagree on the correct spacing between coats. One guy says you can do three coats in a day without sanding by spacing them 6 hours apart (6am, noon, 6pm), then wet sand and put on three more coats if needed before polish-sanding with finer grits. Others say you have to wait 24 hours between every coat and must wet sand (usually with 600 grit) between every coat before polish-sanding.
Has anyone done this? When did you lay down new coats, and did you wet sand between coats?
Thanks!
56chev
Edited by 56chev66must on 08-06-19 04:21 PM. Reason for edit: No reason given.
Member #409
08-11-19 07:00 PM - Post#2772991
    In response to 56chev66must
You can't successfully wet sand Rustoleum.
Execution time: 0.152 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:31 PM
