Username Post: 4L80E        (Topic#357537)
08-05-19 06:29 PM - Post#2772484
any trans experts out there? I have a 4L80E that only goes into 1st gear manualy. it starts off in 2nd and drives normaly. no codes. swapped the speed sensors but same issue. readout shows 1-2 solenoid off in all gears until manually shifted into 1st.
65_Impala
Reg: 12-29-02
08-05-19 07:56 PM - Post#2772497
    In response to bobb
1-2 solenoid should be on in 1st and on in 4th. If it was stuck off then you'd only have 2nd and 3rd.
Intermediate sprag upside down maybe?
Member #409
08-06-19 09:13 AM - Post#2772537
    In response to bobb
If a 4L80E is like a TH400 in 1st/2nd gear in the D position (and I think it is) - 1st gear reaction torque is taken by the low gear sprag in D position. Additionally, when shifted to manual low, the low/reverse band and the sprag take the reaction torque. So no 1st gear unless manually shifted to low means the low gear sprag isn't working.
08-06-19 03:30 PM - Post#2772563
    In response to 65_Impala
My mistake. 1-2 solenoid is on in 4th gear. and when manually shifted to 1st.
65_Impala
Reg: 12-29-02
08-06-19 06:46 PM - Post#2772577
    In response to bobb
If the PCM isn't commanding the solenoid then you won't get 1st gear. Figure out why the PCM doesn't want to use 1st gear.
Execution time: 0.136 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:09 PM
