Username Post: 69 GMC geared too low        (Topic#357521)
Original58
Original58
Loc: Manitoba, Canada
Reg: 10-30-13
08-05-19 03:57 AM - Post#2772438
Hi,
Normally post in 58 section but just picked up a 69 GMC with 4 speed. Its geared low...pulling tree stumps low. Im thinking ithas a sm465 with 4 series gears.
Im wondering if a rear gear change would be enough to be more driveable or should I look at a 5 speed?
Anyone been down this road?
Jeff
1958 Biscayne 283 Turbo-Glide 31,000 mi (now 35,000 and counting) driven daily
1966 Mustang Inline 6- C4 57,000 mi and growing daily
1929 Graham - Paige 612- the eternal headache that I will never sell
08-05-19 02:32 PM - Post#2772472
    In response to Original58
how tall are your tires?
Original58
Original58
Reg: 10-30-13
08-05-19 05:52 PM - Post#2772488
    In response to bobb
Pretty tall already. Its 3/4 ton with 16 in rims.
Ill have to check the size when im back in town.
I could maybe go with 31s but it wouldnt reduce revs by much. Was just curious what others have done.
Jeff
JimKshortstep4x4
Chevytalk Moderator & "15th Year" Silver Supporting Member
JimKshortstep4x4
Loc: Muskegon, MI, USA
08-07-19 03:58 PM - Post#2772651
My son has a 70 GMC, 3/4 ton truck with a TH-350 in it so we understand why you are looking into a fix.
I picked up a 700r4 that we are looking at replacing the TH 350 with. We looked at changing the rear end to one from a C-10 but then addressing the front end and what to do with it is needed. Lower ratios for the 3/4 ton differential were looked into but the choices are limited.
66 Impala SS, 396, TH 400
69 El Camino, 350, TH 350
Original58
Original58
Reg: 10-30-13
08-07-19 06:24 PM - Post#2772662
Thanks for the information. I may need to look at a complete diff and / or a 5 speed.
Once I get more time I'll have to do some calculations on different combinations.
Jeff
64K10
64K10
Loc: Cali
Reg: 06-25-04
08-09-19 07:11 AM - Post#2772797
Do you know what diff and gear ratio are currently in truck? Dana 60?
Probably 4.10 or 4.56 gears depending on engine option (V8 or 6). Gear set may be deeper like 4.88's but that would have been a special order option.
For starters look here for gear sets:
https://www.randysworldwide.com/chevrolet-drivetra...
64K10
Original58
Original58
Reg: 10-30-13
08-09-19 11:58 AM - Post#2772822
    In response to 64K10
Hi. Thanks for the link.
Its a Dana 60. Time to do some calculating.
Jeff
Execution time: 0.075 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:34 PM
