Username Post: powerglide yoke binding on splines        (Topic#357518)
56driver
56driver
Loc: Charlotte, NC
Reg: 02-26-06
08-04-19 02:23 PM - Post#2772406
Strange problem with a stock 56 Powerglide. The original (I think) 16-spline slip yoke bound on the splines, had to be hammered on.
I bought a used one from Eckler's, same problem. Definitely binding on the splines, not the yoke OD, won't go on more than 1".
Pretty sure the binding is between the major diameter of the yoke splines and the OD of the tail shaft splines.
The yoke spline major diameter is about 1.172" measured with cheap dial calipers, which matches about nominal advertised for a new yoke.
As best I can tell the tail shaft splines are around 1.175" - 1.178". I can't see any obvious spline twist, bend, or corrosion.
So I either have two undersized yokes or an oversized tail shaft?
Jonathan Hines
Charlotte, NC
56 BA 4DR sedan undergoing rebuild
56driver
56driver
Loc: Charlotte, NC
Reg: 02-26-06
09-14-19 06:06 PM - Post#2775524
    In response to 56driver
Resolved, by filing the grooves deeper in the slip yoke and sanding the o.d. of the tailshaft with 40 grit sandpaper. Driveshaft slipped right on, no hammering.
Jonathan Hines
Charlotte, NC
Mel Foye
Mel Foye
Reg: 09-29-00
09-15-19 10:05 AM - Post#2775568
Glad you came up with the answer. Mel
Execution time: 0.221 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:07 AM
