Username Post: Parking Brake Warning Switch        (Topic#357509)
Junk86
Reg: 03-15-19
08-04-19 05:51 AM - Post#2772370
Does anyone have a good used one of these available for sale for a 1986 Chevy Camaro 2.8 Sport CP. This is the switch that mounts to the side of the pull back handle that sends the signal to the dash light that lets you know your emergency brake is engaged.
ChromeFinger
ChromeFinger
Loc: Omaha
Reg: 07-08-19
10-17-19 09:12 AM - Post#2778105
    In response to Junk86
If you are looking to stay OEM, other models and year may use the same exact part. Some quality bone yard time maybe fruitful.
If you don't care about factory look and can fabricate, use a micro switch with lever, sold for cheap. 1/8" holes and machine screws will allow mounting and plan for common as ground, then use normally open as lead back to dash light. 1/4" female spades will fit normal terminals.
Just a thought! No one want to drive around with the park brake on.
Execution time: 0.226 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:54 PM
