 Page 8 of 8 « First<5678
Username Post: My '39 Master Deluxe Coupe        (Topic#357502)
06-26-20 07:34 PM - Post#2797271
    In response to 1971BB427
Looks good.
29-41, 42-48, 49-54 Moderator
1971BB427
Loc: Portland,Or
Reg: 12-06-09
06-26-20 08:07 PM - Post#2797273
  • Keith_Knox Said:
Looks good.
Thanks Keith!
1969 Suburban 2wd 350
1939 Chevy passenger coupe
1937 Austin gasser 327/TH350
1971BB427
Loc: Portland,Or
Reg: 12-06-09
06-29-20 02:54 PM - Post#2797462
Figured out my gas gauge issue the other day, and contacted the seller to exchange the gauge. I ordered a 0-90 ohm, and they sent me a 90-0 ohm, thus causing the reverse reading. Got the new gauge today, and got it installed.
I also ordered some thin black foam rubber mat in a 4'x 5' size to put down in the trunk over the floor. I plan to get more black carpet from Home Depot, but want this under the carpet to deaden the noise, but not be slick like the foil back sound deadener is. I wont be gluing the carpet in the trunk, so this will keep it from slipping around also. I'll glue the carpet on the box I built to cover wiring, and vent lines, but leave it removable on the trunk floor.
1971BB427
Loc: Portland,Or
Reg: 12-06-09
07-02-20 05:59 PM - Post#2797753
My wife decided she wanted to help out on the build, so she sewed up covers for the ratty sun visors. She still needs to do the final sewing to close off the end, but they fit well, and look good. The picture makes them look lighter from the flash, but they're very black in reality.
rcr3
rcr3
Loc: MANHEIM PA. U.S.A.
Reg: 11-24-02
07-03-20 05:13 AM - Post#2797773
Nice job!
'67 Camaro survivor
'06 Z71 Sierra Ex Cab
'37 Chevy cp.SOLD!!6/7/14
'74 Nova Custom cp.
'73 Nova pro-street project
'17 Chevy Trax LT
'00 S10 Ex cab
1971BB427
Loc: Portland,Or
Reg: 12-06-09
07-03-20 07:39 AM - Post#2797783
    In response to rcr3
Thanks! Still have to apply the tin layer of dense foam to the visors, and then slip the covering back on so she can do the final stitch to close them off.
1971BB427
Loc: Portland,Or
Reg: 12-06-09
07-03-20 04:48 PM - Post#2797819
Wife finished up my sun visors, and I installed them this morning. They look great, and work nicely!
Then I decided to tackle a job I've been putting off for awhile. The '39 rides pretty stiff, and I planned to remove some leafs up front. Always a guessing game as to how many, and how it will affect the stance. So I decided to go big, and took 3 of the 5 leafs out, but the shortest 3 leafs. That is a total of 3/4" off the stance, and with less spring rate I figured I'd lose another 3/4"-1" on top of that.
So I set about to remove the 3 leafs, and build a spacer block to adjust for the loss. I had plenty of extra length on the U bolts, so I used heavy wall 2"x 2" box tubing, and cut it 5" long. I drilled a hole at center, and opened one side up to 3/8" and the other side up to 9/16" I bolted a stainless steel 3/8" allen bolt in the 3/8" hole to be the alignment pin. The other fits over the 3/8" pin on my springs. Before installing the spacers I cut 2"x 2" plates to weld over the ends of the box tubing to make it stronger, and make it look like a solid block.
Bolted it all together, and lowered the car down on the ground. My before and after measurements were 1/2' difference, and that's 1/2" higher. So it appears my seat of the pants guess on the spacer was as close as I could guesstimate. Love when I get lucky!
Took it for a ride, and even with only two long leafs, the ride is still firm, but not nearly as hard as it was before. Glad to get this mod done, and it actually was a lot easier, and quicker than I thought it would be!
1971BB427
Loc: Portland,Or
Reg: 12-06-09
07-06-20 03:33 PM - Post#2798062
Took a look into installing the electric door locks on the '39 today, and just stuffed them back in the bag for now. Where they attach to the locking mechanism is nearly impossible to access, and if I pull it all out to add the clamp from the kit, I'm unsure how to determine where to clamp it to ensure I can still have the solenoid sitting where it needs to go. So I shelved it for now.
I decided I had enough miles to spend some time going over all the front suspension bolts. Most are grade 8 with locking nuts, so not much that can work loose, but I also had some grade 5 bolts that came with new parts, and wanted to change those out to grade 8.
The Speedway disc brake kit had two 7/16NF locking nuts missing, and I forgot I never replaced those. When I saw they were still regular nuts I got grade 8 locknuts, and figured I'd replace them today. They hold the tierod brackets to the spindles, so pretty important!
When I went to remove the nuts today they had backed off a good 1/8" from tight!! I was shocked to see this, and checked the other bolt that had a locking nut, and they were still tight. But I've had a little bit of "wandering" in my steering, and I bet this was the case. I replaced the nuts with the grade 8 locknuts, and put blue Loctite on all 4 nuts also, just for extra security!
I also replaced all the 1/2NF U bolt nuts for the springs with grade 8 nuts, and Loctited them too. Never seen U bolts with grade 5 nuts before, and didn't like the looks of them for such a critical fastener.
So with everything checked, tightened, Loctied, and changed; I took it for a short spin. The steering is noticeably crisper, and more precise, with no wandering going down the freeway. So I'm glad I took time to check everything after a few hundred miles!
07-06-20 07:21 PM - Post#2798082
Good idea, going over every thing after a new rebuild.
1971BB427
Loc: Portland,Or
Reg: 12-06-09
07-06-20 09:33 PM - Post#2798094
I've always done it, and rarely find anything. But one incident like this makes me sure it should always be done on critical parts like suspension/steering.
1971BB427
Loc: Portland,Or
Reg: 12-06-09
07-11-20 04:42 PM - Post#2798463
Been having issues with my fuel cell QD filler cap. Sometimes I wrestle with it for several minutes at the pump before I get it off. I finally got irritated enough to order a different filler with a 45 degree neck, and pipe thread billet aluminum cap. It arrived this morning, so figured I'd see what it took to replace the old cap. 12 bolts on the outside, with a ring on the inside that hols the 12 nuts. Fun!
Easy to remove, and once I got to the last bolt I reached inside with my fingers to hold the ring as I removed the last bolt. It's a split ring, so I pulled it out to match it to the new filler, and all was good. Then I thought, "How do I hold the ring below, with a 1.25" filler neck on top?"
No way to reach down the neck to hold it! I started one bolt with the new neck turned to one side, but when I tried to swivel it into place the ring moved too! Fought it for awhile, an then decided to bend up two pieces of iron tie wire to make hooks on each end that I'd use to hold the ring up while assembling the filler. I slid the gasket over the wires, and then the plate one wire at a time. Pulled the ring up, and held it with the wires in one hand as I started bolts with the other. A juggling act, and I kept thinking if I dropped it I'd be fishing it out of the fuel cell with my bare hands! Fortunately after a fair amount of struggling, and some cussing, I was able to get some screws started. Then I pulled hard on the iron wire to straighten it out and pull if free of the two holes.
While the filler was out I bent the float arm up too, so it wont have over half a tank when it reads empty! Had to guess what it needed, so hope it leaves me a few gallons when it hits empty, instead of 7 gallons at empty!
And a bonus of changing the filler, (besides easily filling gas!) is I can fill gas right up to the top of the tank now. The filler is about 4" tall, so wont shut the pump off before the tank is full.
1971BB427
Loc: Portland,Or
Reg: 12-06-09
07-13-20 01:51 PM - Post#2798608
I was invited to meet with a car club this morning, by a friend who knows me and the previous owner of my '39 Chev coupe. He told Ed he had a "surprise" for him, and to be sure he made it to breakfast today. Drove out to meet the guys, and Ed showed up late, so didn't get to see his reaction outside, but did see it inside. He was grinning when he saw me, and after saying hello he told me he was tickled to see his old '39 on the road, and done up in gasser style. He added that he was glad somebody got it who followed through with it, as he'd never have gotten it done himself. Another guy asked if he wanted his '39 back, but Ed said it was in good hands, and he couldn't afford it now.
Ed is an old Bonneville racer who runs a '51 Chevy with a 301 straight six, and a lot of other work done to it. It runs 127 mph on the salt, and he's hoping to get it to 130 mph club the next trip down. He spun it out last year at over 100 mph when the clutch began to slip, and thinks it could be close to going 130. But he said the salt is literally eating the car away! In just 6 years of running it there, the fenders, brackets, frame, and most metal parts are falling apart. Even with a pressure washing each time he gets home, it still eats everything up!
Execution time: 0.128 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:49 PM
