 Page 9 of 9 « First<6789
Username Post: My '39 Master Deluxe Coupe        (Topic#357502)
1971BB427
Loc: Portland,Or
Reg: 12-06-09
08-06-20 12:04 PM - Post#2800449
    In response to 1971BB427
Got the 2nd seat upholstery sewed up, and managed to stay on my lines this time, so no redo on this one. Then got it back on the frame after some wrestling. Of course whenever I think I got the toughest half done, I always find out it wasn't, and the 2nd one was tougher. It require me to remove the foam from the frames, and install the upholstery to the foam partially. Then reinstall the foam, and covering, and finish locking it down to the frames then. A lot more work, but it did go on after some coaxing. Had to reach up inside the upholstery to hook some plastic stays the factory uses to pull the fabric into the seat. Good time to have these long arms that allow my knuckles to drag the ground!
Got the seat bolted back in after the morning rains stopped, and just need to do the weatherstrip around the doors now.
1969 Suburban 2wd 350
1939 Chevy passenger coupe
1937 Austin gasser 327/TH350
41wildthing
41wildthing
Loc: NJ
Reg: 12-02-15
08-09-20 07:15 AM - Post#2800665
Looks really nice and the door, quarter and rear storage/trunk divider panel came out very well.....Phil
1971BB427
Loc: Portland,Or
Reg: 12-06-09
08-09-20 07:38 AM - Post#2800671
    In response to 41wildthing
Thanks Phil! I have a grand total of about $500 into the interior, including buying the bucket seats, and the sewing machine. So being the tightwad I am it fits into my low budget build theme.
41wildthing
41wildthing
Loc: NJ
Reg: 12-02-15
08-09-20 10:46 AM - Post#2800687
Wow. You really got a bargain on the machine considering that you got a table with it. Does it do zigzag as well as straight stitch?......Phil
1971BB427
Loc: Portland,Or
Reg: 12-06-09
08-10-20 09:04 AM - Post#2800775
Thanks. No, as I said earlier this is a 1950's sewing machine, and doesn't even have reverse. I have to leave the needle in the fabric, raise the foot, and turn the material 180 degrees to reverse the stitch.
Not sure what I'd use zigzag for on auto upholstery? But it does have a box full of extra attachments for different feet, etc., and I believe one of them is to guide material to make piping for seat edges.
I'm still learning the sewing, and the machine, but since my plans to resell changed with this machine being so cheap, I'll have plenty of tasks to try it on, and see what all it can sew.
1971BB427
Loc: Portland,Or
Reg: 12-06-09
08-10-20 09:04 AM - Post#2800776
Execution time: 0.254 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:34 AM
