 Page 8 of 8 « First<5678
Username Post: My '39 Master Deluxe Coupe        (Topic#357502)
06-26-20 07:34 PM - Post#2797271
    In response to 1971BB427
Looks good.
29-41, 42-48, 49-54 Moderator
1971BB427
Loc: Portland,Or
Reg: 12-06-09
06-26-20 08:07 PM - Post#2797273
  • Keith_Knox Said:
Looks good.
Thanks Keith!
1969 Suburban 2wd 350
1939 Chevy passenger coupe
1937 Austin gasser 327/TH350
1971BB427
Loc: Portland,Or
Reg: 12-06-09
06-29-20 02:54 PM - Post#2797462
Figured out my gas gauge issue the other day, and contacted the seller to exchange the gauge. I ordered a 0-90 ohm, and they sent me a 90-0 ohm, thus causing the reverse reading. Got the new gauge today, and got it installed.
I also ordered some thin black foam rubber mat in a 4'x 5' size to put down in the trunk over the floor. I plan to get more black carpet from Home Depot, but want this under the carpet to deaden the noise, but not be slick like the foil back sound deadener is. I wont be gluing the carpet in the trunk, so this will keep it from slipping around also. I'll glue the carpet on the box I built to cover wiring, and vent lines, but leave it removable on the trunk floor.
1971BB427
Loc: Portland,Or
Reg: 12-06-09
07-02-20 05:59 PM - Post#2797753
My wife decided she wanted to help out on the build, so she sewed up covers for the ratty sun visors. She still needs to do the final sewing to close off the end, but they fit well, and look good. The picture makes them look lighter from the flash, but they're very black in reality.
rcr3
rcr3
Loc: MANHEIM PA. U.S.A.
Reg: 11-24-02
07-03-20 05:13 AM - Post#2797773
Nice job!
'67 Camaro survivor
'06 Z71 Sierra Ex Cab
'37 Chevy cp.SOLD!!6/7/14
'74 Nova Custom cp.
'73 Nova pro-street project
'17 Chevy Trax LT
'00 S10 Ex cab
1971BB427
Loc: Portland,Or
Reg: 12-06-09
07-03-20 07:39 AM - Post#2797783
    In response to rcr3
Thanks! Still have to apply the tin layer of dense foam to the visors, and then slip the covering back on so she can do the final stitch to close them off.
1971BB427
Loc: Portland,Or
Reg: 12-06-09
07-03-20 04:48 PM - Post#2797819
Wife finished up my sun visors, and I installed them this morning. They look great, and work nicely!
Then I decided to tackle a job I've been putting off for awhile. The '39 rides pretty stiff, and I planned to remove some leafs up front. Always a guessing game as to how many, and how it will affect the stance. So I decided to go big, and took 3 of the 5 leafs out, but the shortest 3 leafs. That is a total of 3/4" off the stance, and with less spring rate I figured I'd lose another 3/4"-1" on top of that.
So I set about to remove the 3 leafs, and build a spacer block to adjust for the loss. I had plenty of extra length on the U bolts, so I used heavy wall 2"x 2" box tubing, and cut it 5" long. I drilled a hole at center, and opened one side up to 3/8" and the other side up to 9/16" I bolted a stainless steel 3/8" allen bolt in the 3/8" hole to be the alignment pin. The other fits over the 3/8" pin on my springs. Before installing the spacers I cut 2"x 2" plates to weld over the ends of the box tubing to make it stronger, and make it look like a solid block.
Bolted it all together, and lowered the car down on the ground. My before and after measurements were 1/2' difference, and that's 1/2" higher. So it appears my seat of the pants guess on the spacer was as close as I could guesstimate. Love when I get lucky!
Took it for a ride, and even with only two long leafs, the ride is still firm, but not nearly as hard as it was before. Glad to get this mod done, and it actually was a lot easier, and quicker than I thought it would be!
Execution time: 0.33 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:22 AM
