 Page 7 of 7 « First<4567
Username Post: My '39 Master Deluxe Coupe        (Topic#357502)
1971BB427
Loc: Portland,Or
Reg: 12-06-09
05-31-20 04:50 PM - Post#2795341
    In response to 1971BB427
Darn it! I went into the shop last evening and the headliner material around the top of the back window was loose and hanging in the air! I glued it all around with 3M headliner glue, but it didn't hold. It's the only area without a tack strip, and I suspect it should have one, but no idea.
It has a tack strip along the top of the windshield opening, and I stapled and glued it there, and that held great. Asked about on the rear, but didn't get any response.
So today I came up with my own fix. I sat down in the back with a 1/8" drill bit, and a bunch of 1/8" pop rivets, and set off to drill and rivet the headliner to the metal structure around the frame. Put a rivet every few inches and twice as close in the corners.
This seems to be holding great, and once the weatherstrip is in place it will be even better! I would have simply made a tack strip, but no idea where it would mount and not interfere with the weatherstrip? No signs of where one could have been, but shop manual says the headliner gets "glued and tacked around the window", so must have had something?
Clean up day tomorrow again! Even with not bodywork, it seems to be covered in dust. Rolling it outside tomorrow, and doing a deep cleaning, which means I'll get wet as I plan to scrub the engine bay, frame rails, and everything I can reach! It all looks like 10 years of accumulated dust!
1969 Suburban 2wd 350
1939 Chevy passenger coupe
1937 Austin gasser 327/TH350
Execution time: 0.227 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:18 PM
