Username Post: Carb to fuel pump line        (Topic#357494)
2tone50
2tone50
Reg: 08-02-19
08-02-19 04:37 PM - Post#2772267
Howdy, noob here. I stripped the threads on the fitting that goes to the carb from the fuel pump. Is it possible to replace or do I need to make a new line? Also trying to swap the rochester for a carter and it seems a bit cramped to wrench on around the base from the old rochester. Any guidance would be appreciated, it's a 1950 3100 with 235.
08-04-19 11:22 PM - Post#2772430
    In response to 2tone50
pics would help
2tone50
2tone50
Reg: 08-02-19
08-05-19 12:06 PM - Post#2772459
    In response to bobb
https://m.imgur.com/a/rNs4EkZ
Hope this helps still cant attach photos for some reason.
Attachment: 30eQFd5.jpg (845.52 KB) 24 View(s)
08-05-19 03:00 PM - Post#2772470
Hey 2tone50,
you first need to download the image to your PC before you attach them. You can't attach remotely stored images.
Edited by Tony on 08-05-19 03:01 PM. Reason for edit: No reason given.
2tone50
2tone50
Reg: 08-02-19
11-01-19 04:17 PM - Post#2779323
Ahhh I feel really dumb, didn't realize that this was the vaccum advance line. Does anyone know where I can find fittings for this or do I need to tap out the distributor and the carb base for something else? The fitting on the distributor fits the one on the carb. Sorry for the late reply.
Attachment: 74456376_531764254337946_4473613316761059328_n.jpg (505.22 KB) 12 View(s)
WagonMan
WagonMan
Loc: Las Vegas, NV
Reg: 10-26-04
11-04-19 12:04 AM - Post#2779503
Same as brake line tubing.
Charles
57 210 4dr. Wagon(bought '82)
-350/700r4 Mild Custom
29 Ford Sedan(bought '75)
-4.3L/TH350(in progress)
Execution time: 0.154 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:44 PM
