Username Post: High fuel pressure at idle        (Topic#357472)
tkdtkd
tkdtkd
Loc: Marietta, Georgia U.S.A.
Reg: 08-29-02
07-31-19 06:41 PM - Post#2772131
1999 5.3 has good fuel pressure when key is turned on. At idle the gauge pegs over 100.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
07-31-19 08:52 PM - Post#2772139
    In response to tkdtkd
If it is truly pegging over 100 I would say the regulator is shot. That is high
Old School GM fan FOREVER
Senior Moderator
08-01-19 04:25 AM - Post#2772153
    In response to rockfangd
*Fuel* pressure is 100psi at idle? Not sure the fuel pump is capable of deadheading that much pressure...
Is the truck running properly? Do you have another gauge you can test against? You can probably borrow/rent one from the auto parts store.
tkdtkd
tkdtkd
Reg: 08-29-02
08-01-19 04:56 AM - Post#2772155
    In response to someotherguy
LS swap with new inline pump. With just key on it reads good (Autozone gauge). Idle is a little rough but it is new to me, so not sure if that statement is true. Smooth when pedal stepped on. It was giving both upstream O2 codes and I changed those. Sensors appeared to be original. Maybe return clogged? Regulator?
tkdtkd
tkdtkd
Reg: 08-29-02
08-02-19 09:30 AM - Post#2772237
Tried blowing 40 psi air down the return line. Also changed the regulator neither was the answer. Found a clamp on the return line. Took off the clamp and it ran at 50 psi, but spewed gas out the return line. Guess who is pulling the fuel tank?
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
08-03-19 08:31 PM - Post#2772351
so you are thinking there is a restriction on the return side?
Wonder if it is a kinked or pinched line at the tank
tkdtkd
tkdtkd
Reg: 08-29-02
08-04-19 07:15 PM - Post#2772420
Pulled the tank and hose clamps on the sender were loose. All the lines were run proper just not tightened..There was a clamp on the return making no return and lots of pressure. Everything was new, hose and clamps. I hate pulling fuel tanks. But it runs at 50 psi now.
Site Ambassador
08-05-19 06:48 PM - Post#2772487
Good to hear that it was a relatively easy fix.
1957 Cameo Carrier
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
08-05-19 06:56 PM - Post#2772491
    In response to wagonman100
There you go. Found and solved.
Congrats.
Execution time: 0.1 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:55 AM
