Username Post: Contemplating mini-tubbing a '63 Biscayne Wagon...        (Topic#357464)
BowtieGent
BowtieGent
Loc: Mission, BC.
Reg: 05-07-13
07-31-19 08:21 AM - Post#2772087
Hey All, Posting for a friend.
As the header states, Has anyone mini-tubbed these wagons before, and if so, any advice or photos of the modification?
Thanks.
Nitrous is like a hot girl with STD's…You know you wanna hit it, but you’re afraid of the consequences!
1965 Biscayne 2 Door Post: 350,PG,373-posi,C3-DB, PS,PB.
1970 Chevelle Malibu: 53 on 753.
Brian Daniel McClure: 1970-2015. R.I.P. Brother.
BowtieGent
BowtieGent
Loc: Mission, BC.
Reg: 05-07-13
08-09-19 08:34 AM - Post#2772799
    In response to BowtieGent
Nothing?
junky
Loc: Northeast CT
Reg: 06-27-10
08-09-19 09:17 AM - Post#2772804
I haven't a clue as to what you are referring to. Must be a generational gap in the English language..... unless you are referring to cutting out the wheel wells to install larger tires? If so all you need is the guts to do it right, or ruin your car. This type of surgery isn't for the faint of heart, but for serious people that understand body building (not the human body building)and can do it well. Most of those that did these type of mods were the drag racers of the 1960's.
BowtieGent
BowtieGent
Loc: Mission, BC.
Reg: 05-07-13
08-14-19 01:18 PM - Post#2773224
    In response to junky
Mini-Tub, as opposed to Full-Tub for full on racing tires.
So, What you're saying is that unless building a drag car, No-one has put in the time and effort to "mini-tub" (widen the rear wheelwells...for the generation gap) a wagon just to allow for wider tires...?
gofastwclass
Loc: In the garage
Reg: 08-19-14
08-14-19 08:46 PM - Post#2773240
I don't believe Junky is saying no one has done it. He is simply saying most do wheel tubs with the eye toward drag racing.
As a person who understands mini tubs and their benefits, can it be done - yes. However a wagon is a bit of a different beast than a regular car or truck because ideally the interior would need to fit and work like factory once the task had been completed.
Keeping things working and looking like it was a factory job (the point of mini tubs in my eyes) would take a LOT of planning, time, attention to detail, metal working experience and an eye for proportions to pull off. Get it wrong and the car ceases to appear (or function like) factory. Removing the rear seat or making a seat that didn't fold down would remove a lot of complexity but it's still a big process from scratch (no suitable kits I'm aware of).
Example: the wagon I worked on a few years ago had the folding rear seat and floor. We talked about mini tubs on that car but when we went over all the necessary things required to keep his interior functioning like stock he changed his mind.
In short you are going to need to think about modifying four major components of the car plus any ancillary items:
1. body (and mounts)
2. frame (and mounts)
3. axle housing
4. interior (highly visible rear seating area and panels)
The first three aren't too bad for an experienced fabricator but number four will be the difference between just looking OK and the finished car appearing unmodified.
Finally, depending on the wheel diameter, offset, ride height and axle width you can fit and drive on a 10" wide wheel in an otherwise stock wagon body. Now the question becomes how wide does your friend really want to go?
1961 Impala mild custom build
Gofastwclass on YouTube
Why buy when you can build it better?
BowtieGent
BowtieGent
Loc: Mission, BC.
Reg: 05-07-13
08-22-19 11:12 AM - Post#2773818
    In response to gofastwclass
3. axle housing
THIS, Is exactly what I expected from the question I asked, Thank You gofastwclass.
I know it can be done, and how complex portions of the changes can have a detrimental outcome if rushed or not thought out to every detail.
Usually I post in the '65-'66 section, and have photos of metal work I've finished recently on a good friend of mines '65 Ragtop SS.
The mini-tubbing is just an idea that crossed my other buddy's mind and thought i'd reach out here for feedback to pass along to him.
I appreciate your reply.
Execution time: 0.152 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:23 PM
