Username Post: gear oil        (Topic#357443)
george88gta
george88gta
Loc: new york
Reg: 04-23-03
07-29-19 01:58 PM - Post#2771937
Not trying to start an "oil war", but I do have a question. I am having the rear differential rebuilt. I presently have aftermarket "street gears" installed and it is too noisy for me. I have to wear hearing aids and between 40 -60 mph, the gear whine is excessive. Getting old sucks, but I hope you all get there. Anyway, the last time it was upgraded, I used an Auburn posi unit. No complaints. I have to purchase some gear oil since I am switching to a GM gear set to try and reduce the noise/whine. I have some redline on the shelf. OK to use or should I get some non-synthetic and the GM additive?
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
07-29-19 02:03 PM - Post#2771938
    In response to george88gta
If you are getting that kind of noise either the setup is wrong or a bad cut on the gears. Lubricant brand won't quieten them.
george88gta
george88gta
Loc: new york
Reg: 04-23-03
07-29-19 02:18 PM - Post#2771939
    In response to aghaga
Best guess is that the gears are just "robust". Not just changing the oil, I am replacing the aftermarket gears with a GM set. Question was directed at which oil to use with an Auburn posi.
jdk
jdk
Loc: columbus, ohio
Reg: 02-15-10
07-29-19 02:24 PM - Post#2771940
get a couple gm additives in there and do some
figure 8's. jim
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
07-29-19 02:31 PM - Post#2771942
My bad, don't know how I missed that you were changing the bad set for a GM set. Auburn has a recommended friction modifier to add to the gear oils. Red Line is a very good lube but I don't know if it has a comparable additive already mixed in. Give the info on the container to a representative to find out.
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
07-29-19 02:34 PM - Post#2771943
I found this on another forum from Auburn:
"Good morning,
We do not suggest synthetic oils in our units for the very reason of the noise that you are getting in the rearend. Our recommendation is to use an OE 80/90 wt. oil with and OE additive.
Put in approximately 3 ozs. of additive for every quart of oil. Avoid synthetic oils and K & W brand of additives.
Let us know if we can further assist you. Have a great week!"
Hope this helps.
george88gta
george88gta
Loc: new york
Reg: 04-23-03
07-29-19 02:39 PM - Post#2771944
    In response to jdk
OK, lets try this again. The car is a survivor 2002 Trans Am convertible (non-WS-6).I am the second owner ( I have the original title and bill of sale). It is a rare color combo. No burnouts, no donuts nor figure 8's are going to happen. It deserves to be preserved. It is only a local cruiser. I changed the rear gears from 2.73 to 3.23 so it would be a better driver around town. Wont do that again. Switching back to the 2.73 would require a new posi unit, somewhat expensive.
george88gta
george88gta
Loc: new york
Reg: 04-23-03
07-29-19 02:41 PM - Post#2771945
"Good morning,
Hope this helps.
Thats what I am looking for, some solid info. Off to NAPA and GM for the right oil and additives. Gas mileage isnt much of an issue since it rarely goes too far.
Edited by george88gta on 07-29-19 02:42 PM. Reason for edit: No reason given.
07-29-19 03:53 PM - Post#2771952
The correct suggestion to do figure 8's is done to get the lube into the posi clutches or cones.
IgnitionMan
Reg: 04-15-05
07-29-19 05:24 PM - Post#2771959
The gear noise is from them not set up correctly, find another tech that knows how to do it right.
Then, NO SYNTHETIC SNAKE OILS , use a good natural gear oil, 85/90 weight, or, I prefer 90/140 weight, and the correct additive for the type diff it is, open, or posi-traction.
george88gta
george88gta
Loc: new york
Reg: 04-23-03
07-30-19 03:15 AM - Post#2771981
    In response to IgnitionMan
Thats the plan. We have a local tech, who worked for GM many years and decided to open his own shop. He has a great reputation for quality work. I used him in the past, only sorry I went with someone else for the first gear change.
IgnitionMan
Reg: 04-15-05
07-30-19 03:24 AM - Post#2771982
Most gear noise is caused when the pinion depth isn't correct. When that happens, the ring gear doesn't sit correct, even if the back lash is correct. It is a delicate balancing act at very best, disaster when wrong.
Sounds like you are going to get it handled right, good for you, sir.
elcamino
elcamino
Reg: 03-30-00
07-31-19 04:05 AM - Post#2772064
A 75W-90 synthetic gear lube with limited slip additive will work. Anyone who recommends not using synthetic gear lube has no idea what modern synthetic oil is. GM has been factory filling rear differentials with 75W-90 synthetic gear lube since the early 1990's.
Synthetic oil base stocks are enigneered from synthetic hydrocarbons using a process that re-arranges the structure so all the molecules are uniform in size, shape and weight, a phenomenon that does not occur in nature. In contrast to petroleum oils which are pumped from the earth and refined. Synthetics are custom-designed to produce, in effect, the ideal lubricant.
2017 GMC Sierra Denali Ultimate 6.2L / 8-sp Z95
2018 Polaris RZR S 900 EPS
IgnitionMan
Reg: 04-15-05
07-31-19 06:36 AM - Post#2772081
    In response to elcamino
Oh, really? Then, why did I spend over 30 years fixing synthetic oils damage to early parts that did NOT have the correct metallurgy and/or hardness to use that junk.
A roller cam, induction hardened engine, or differential may well work just dandy with 0W-nothing synthetic "oil", but not an earlier part made out of silly putty metals.
After trying to work with Bel-Ray oil people trying to make their stuff work for over 5 years in components that had correctly hardened parts, and only finding bad results, we finally went back to natural oils, and the oil failures stopped.
So, you now see, I am not ignorant about today's snake oils, nor the metals they cause to fail. Next time you want to call someone as not knowing, learn what they do know....before proving you don't know them, nor their experience at all.
george88gta
george88gta
Loc: new york
Reg: 04-23-03
07-31-19 09:42 AM - Post#2772094
Directly from the Auburn Q+A section of their website:
"Q23. What kind of oil should be used with an Auburn limited-slip differential/ Auburn ECTED Max differential?
A23. Non-synthetic 80w90 GL-5 oil treated with Auburn Gear friction additive, part #504102 (also known as a friction modifier). See Catalog page 32. Three (3) ounces of additive will treat one quart of oil. GM or Ford limited-slip additive may be used. We do not recommend synthetic oil. Auburn limited-slip additive is packed in every box with the differential."
Since I have an Auburn unit installed, I will go with their recommendation.
IgnitionMan
Reg: 04-15-05
07-31-19 02:49 PM - Post#2772117
Good, use what you wish, but, don't call anyone else dumb, idiot, moron, stupid, LIAR, nor that they don't have any knowledge of a subject, when they clearly do.
Member #409
07-31-19 06:17 PM - Post#2772132
Just who said that to your sensitive ego? No one in this thread.
The recommendation he got from Auburn was the same as yours. Where's the beef?
65_Impala
Reg: 12-29-02
08-01-19 04:52 PM - Post#2772197
    In response to Rick_L
Because he's not happy unless he's beefing about anyone else's opinion to the point of posting silly BS to support his claims....
The auburn recommendation to use dino oil has nothing to do with the gears or bearings, since neither is part of the posi unit they sold. Those parts are always be better served by a good synthetic oil. They must believe the dino oil helps the clutches work better.
scrambldcj8
scrambldcj8
Loc: Belchertown, MA
Reg: 04-06-03
08-03-19 04:31 PM - Post#2772340
Is it noisy AFTER the rebuild or it has been noisy all along since a previous rebuild?
My brother didn't take my advice on a shop once and had it done at a lesser known shop....gear whine whine whine. Shop says let them break in....no dice!
Went to suggest shop....incorrect setup/install. Lesson learned.
george88gta
george88gta
Loc: new york
Reg: 04-23-03
08-04-19 03:48 AM - Post#2772366
    In response to scrambldcj8
Went to suggest shop....incorrect setup/install. Lessoned learned.
It had the orinal 2:73 gears when I purchased the car. They were nice and quiet, no whine. Since the car is basically a local cruiser, I thought that it would perform better with 3.23 gears. This resulted in a different posi unit, due to the gear ratio change. After market street gears installed and now whining. Could be incorrect install or type of gears or both. Can't go back to the 2.73 unless I want to spend the money on a new posi. I have a set of GM 3.23 gears and a reputable shop. So that is the plan. Hope it works out.
Execution time: 0.114 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:10 AM
