Username Post: A/C gauges        (Topic#357412)
Senior Chevytalk Moderator
07-28-19 08:19 AM - Post#2771800
Can anyone recommend a good set of gauges for A/C work? I get by on a set from Harbor Freight. However the number of peeps calling for charging is going up. Everyone needs A/C work sooner or later. Are digital gauges good? I like the newer style where you can connect to ports then open them. The new self sealing R134 cans are a PIA. The adapter is reverse piercing. Plus you need to find the sweet spot where it's actually open.
Tool Topia seems to have a nice range of gauges.
100 CHEVY
100 CHEVY
Loc: Helena,Missippi,U.S.A.
Reg: 12-09-04
07-28-19 09:37 AM - Post#2771806
I can't suggest a particular brand of gauges.I have 6 or 7 sets I use.
And,I don't use can taps.I buy refrigerant in 30 lb canisters at the supply house.It's cheaper by volume.
And,a set of scales wouldn't hurt either.
Mike.
07-28-19 12:56 PM - Post#2771818
    In response to 100 CHEVY
What's a scale? I use a factory chart and pressure. Close enough people don't complain.
Are block aluminum gauges better than old brass style? I guess I could swap the gauges on the aluminum block.
How do you dispense from a 30 lb can?
100 CHEVY
100 CHEVY
Reg: 12-09-04
07-28-19 05:07 PM - Post#2771837
I prefer the brass gauges myself.
I still have a set of gauges from my dad.
The center hose on the hose set is for outside connection to vacuum pump(and,can taps)or to the tap on the drum.
Vent the hose at the gauges to remove the air in the hose and then open the valve to the cars system to charge.
Mike.
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
07-28-19 05:51 PM - Post#2771844
I have a set of Robinair gauges that are getting close to 20years old now. The cheap ones are just that!
100 CHEVY
100 CHEVY
Reg: 12-09-04
07-28-19 06:54 PM - Post#2771853
    In response to junkman104
I have my dad's that are over 20 years old and his Robinair vacuum pump.
The gauges are easily re-buildable too!
They are good tools.
Mike.
09-22-19 10:16 AM - Post#2776131
Okay, here's another question. One thing I've not seen addressed in hundreds of videos, temperatures. Though temperatures vary, some things should be identifiable. Large temp differences can identify a clogged condenser. I'm curious, what kind of temp readings should be across expansion valves or orifice tubes?
100 CHEVY
100 CHEVY
Reg: 12-09-04
09-22-19 03:32 PM - Post#2776176
That's hard to answer.
The temp reading will be different at different times during the cooling cycle.When you first turn the a/c on,the temp will be very cold at the expansion device.As the cabin temp cools down,the temp will be different as cabin temps change.
When the cabin is "cool"(and system is charged correctly)the inlet and outlet temps at the evaporator will be almost the same.
I'm sure one of my a/c books would explain this better,but this is the best I can do!
Mike.
Execution time: 0.065 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:27 AM
