Username Post: 85 305 oil filter question        (Topic#357370)
Mad Professor
Reg: 12-30-08
07-25-19 06:31 AM - Post#2771522
I've got an 85 C10 I'm getting ready to put on the road.
I want to go through the filters and such. I've not played with a 305 but have lots of experience with older 350s.
Question is can you use the longer spin on oil filters on the 305 blocks?
Maybe a part number?
62 Willys wagon
67 CJ5 Buick V6 w/OD
85 C10 305, SM465
89 S10 baja package
07-25-19 03:30 PM - Post#2771567
    In response to Mad Professor
305 and 350 SB are the same block. There are some rare exceptions. Only bore and stroke are different. The 305 can accept a longer filter as long as it screws on. Carb fuel filters are the same.
'08 GMC Acadia 3.6L SLE
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
07-27-19 11:53 AM - Post#2771726
STP S373 or equivalent
It is the 2qt big truck filter. Same diameter as a S5 but twice as long. Bottom of the filter will sit even with the bottom of the stock oil pan. Be sure to fill the filter with oil before you screw it on to prevent a dry start. Fill the filter, then put 4 qts in the crankcase. Start the engine and then shut it off. Should be about the right oil level. If not add to the fill line. Reason I say this is the capacity changes and it is no longer 5qts with filter.
Edited by 1983G20Van on 07-27-19 11:56 AM. Reason for edit: No reason given.
56sedandelivery
Gold Supporting Member
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
11-06-19 12:02 AM - Post#2779646
Actually, only the bores are different; they all (267, 305 and 350) share the same stroke at 3.48 inches, and they share the same crankshaft casting numbers; they are balanced to a different bob weight however. I have a real odd ball "305"; .030 over, cut down 400 crank, 400 rods, and a forged 305 piston, for 334 CID. Only drawback is the stock #601 casting heads; really needs bigger valves and ports. I am Butch/56sedandelivery.
Mad Professor
Reg: 12-30-08
11-21-19 11:57 AM - Post#2780674
SBC came with a number of different strokes:
265/283/302 3.00
262 3.10
307/327 3.25
267/305/350 3.48
400 3.75
These are just the old school ones
62 Willys wagon
85 C10 305, SM465
89 S10 baja package
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
11-25-19 05:11 PM - Post#2780950
And, Fram PH373 (some would say the worst filter out there...unless you go up in product line).
Wix and Napa make a filter too.
I bet that it will be easier to cross=over the Fram number.
As far as filters go, a 305 is a 350.
If you don't have room...there is room in my 2wd Sub, and my last 4x4 PU, but it you don't, the 1 qt filter is PH5
Edited by Stinky on 11-25-19 05:13 PM. Reason for edit: No reason given.
Execution time: 0.178 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:59 AM
