Username Post: Question: '64-'66 Rear Axle Panhard Bar Mount.        (Topic#357366)
64K10
64K10
Loc: Cali
Reg: 06-25-04
07-24-19 10:40 PM - Post#2771503
Ok, here's a couple of questions for you '64-'66 coil spring rear axle truck owners. On the 12 Bolt (truck) rear axle there's a large loop, top right hand side, cast into the pumpkin. In this loop there is a ~5" long shaft that bolts into/through "it" and is attached with nut and lock washer. The lower panhard bar end would then attached to the shaft.
I'm stripping the axle assembly apart to get it powder coated.
Q1. With the nut/lw off, which direction does the shaft slide to remove it from the loop?
Q2. Are the loop hole and shaft tapered?
Q3. Did you use a "puller" to get it off or a BFH?
64K10
64K10
64K10
Loc: Cali
Reg: 06-25-04
08-09-19 07:47 AM - Post#2772795
    In response to 64K10
The answers are:
A1. The short, large threaded side of the shaft is driven out from the loop on the diff. Spray with PB Blaster or similar and let soak overnight.
A2. Yes, loop and shaft are tapered.
A3. Use a BFH and a large punch to drive the shaft from the loop.
64K10
Edited by 64K10 on 08-09-19 01:59 PM. Reason for edit: No reason given.
Execution time: 0.102 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:21 AM
