Username Post: What size brush - oil return        (Topic#357353)
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
07-24-19 02:19 AM - Post#2771416
I am wanting to run a brush all the way down the oil return galley that starts in the cylinder heads on my 350 engine however the array of sizes is baffling! What size will do the job?
Thanks.
Stan
It's all good. mostly
07-24-19 12:30 PM - Post#2771462
    In response to 4dr 57
There is no "oil return galley". There is a simple hole at the end of each head, and it is quite short in length. So the hole you see is the size you need to fit. The hole connects to the block valley area where the lifters are - big volume.
4dr 57
Reg: 11-10-04
07-26-19 05:57 AM - Post#2771636
    In response to Rick_L
Thanks Rick yes, I see that now!
Guess my oil control is ok - it's just a leaky valve cover gasket. I had concerns that the hole was plugged and loading up under the valve cover.
Execution time: 0.083 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:38 AM
