Username Post: 4 speed to automatic?        (Topic#357346)
MikeH
Loc: Abington, MA
Reg: 09-24-02
07-23-19 12:28 PM - Post#2771382
So after many years with a Muncie M21 and 3:08 rear in our 57 Bel Air we have decided to look into converting to an automatic transmission. Except for the American Racing TT wheels and stick on the floor the car looks original and the plan has always been to keep it this way. I did put in a crate 350/390HP a few years back. I would like members thoughts on what tranny (on a budget) would be the simplest way to convert. My steering column still has the setup for a shifter in the tree, but I would not rule out a floor mount shifter. In all honesty our previous 57 was all stock with 283ci and Powerglide and we were very happy with it. Am I unrealistic to think I could match a Powerglide to the 350 without a lot of modifications?
Thanks ahead for your thoughts.
MikeH
Bad56Sedan
Bad56Sedan
Loc: Pasadena, Texas
Reg: 04-29-04
07-23-19 02:15 PM - Post#2771389
    In response to MikeH
Simplest on a budget;
Turbo 350/converter/ dip stick & tube,
External Trans cooler an option
After market floor shift,
Rear trans mount/ brackets,
Drive shaft to trans yok, unless yours fits the new trans,
New u joint if you swap yok,
Verify drive shaft length is ok,
(Consider side mounting block, unless it already is or,
Consider using rear block/trans brackets to frame horn mounts,
sold at one of the after market boutiques, or chain down front driver side of block to frame)
(I' m guessing a turbo 350 is the cheapest)
My thoughts, it's what I did
VC56S 2 door Sedan, 40 Years
Edited by Bad56Sedan on 07-23-19 02:16 PM. Reason for edit: No reason given.
07-23-19 04:15 PM - Post#2771395
I wouldn't even think about using a 2 speed powerglide. Since your changing, go with a 4 speed overdrive, a 700R4 or 2004R. Not any more trouble than a powerglide or th350 and the cost is well worth it for years to come. Cruising down the freeway at 1800 RPM is sure nice.
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
07-24-19 02:11 AM - Post#2771415
    In response to acardon
Wouldn't a 350 trans with the lock-up/lock-out feature be equally as beneficial? I converted from a 350 to a TH400 trans in hope of gaining better MPG - that didn't happen - 1 mpg improvement under ideal driving conditions. I wish I had never bothered with it, it's all hype. The 350 with the lock-out feature is the same as OD and it is cheaper to buy/rebuild. My $.02
Stan
I'd rather be thorough than vague
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
07-24-19 05:06 AM - Post#2771427
X2. I did this swap several years ago replacing a manual with a 700R4 and I am happy with my decision.
07-24-19 06:42 AM - Post#2771435
3.08 rear with an od trans is not a good combo, we recommend 3.55 or even 3.73 in my shop.
07-24-19 07:36 AM - Post#2771443
The 700R4 has a pretty low 1st gear so getting it moving with a 3.08 shouldn't be a problem, with 390 HP. I had a 3.08 in my 57 with 350 HP and it did fine, excerpt it was noisy. I replaced it with a 3.36 only because it was free.
557B2100
557B2100
Reg: 06-02-13
07-24-19 06:35 PM - Post#2771489
Agree 100% with Don...The 3.06 first gear of TH700-R4 is a good match for a 3.08 rear end.
Site Ambassador
07-24-19 07:36 PM - Post#2771493
    In response to 557B2100
The lock up on a TH350 is not the same as overdrive. You lose some of the converter slippage but you don’t get the gear reduction of overdrive. The 700-R4 does have a low first gear, but remember it has a pretty wide gap for second gear. The 3.08 gears will do fine, but may not feel the peppiest off the line. I have a 700-R4 with 3.50:1 gears and a 25” tall tire in my El Camino and it is pretty quick off the line and cruises at around 2,000 RPM at 70 MPH.
1957 Cameo Carrier
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
07-25-19 03:11 AM - Post#2771508
IMHO, I would go with the 700-R4. I'm running one in my '53 Sport Coupe with an 8.2 inch 3.08 rear end from a '70 Nova. A lower ratio would be better than a 3.08 with the OD transmission but I'm using what I have for now. I may go to a 3:55 posi at some point. That said, if your Powerglide is in good shape and you are happy with it, I would not hesitate to keep it. It should be pretty much a bolt-in to the 350. Just remember that you will get better gas mileage and performance from the 700-R4 than the Powerglide but if those are not your goals then keep the Powerglide. If the Powerglide needs a rebuild or has very high mileage on it, I would definitely not use it.
Vern
1953 Chevy Belair Sport Coupe - 355 Blueprint Engine, 700-R4, EZ Wire, Vintage Air, Ididit column, Cruise/Tilt, PS, 59 Corvette Steering Wheel, 4-Wheel Discs, Posies Rear Springs, Coker Radials, Nova 10-bolt, Mustang II, NCA Continental Kit.
07-25-19 05:36 AM - Post#2771519
Is you engine a later model with a one piece crank seal?
Isn't the power glide flex plate unique to cast iron power glide only, and won't bolt to the one piece seal crank?
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
07-25-19 06:56 AM - Post#2771524
Original poster posted,
(On a budget)
From one of the big parts places,
A turbo 350 is just under $1000,
A 700R4 is around $1500,
I must have misunderstood "on a budget" as meaning cheapest
57tim
57tim
Loc: Cameron, Wi, USA
Reg: 11-09-01
07-25-19 02:52 PM - Post#2771562
    In response to Bad56Sedan
IMHO you are wasting your money going to a turbo 350. I would never go with a Powerglide either. Save up some more and get an OD trans.
57 Bel Air 2dr Ht
327 700r4
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
07-25-19 03:31 PM - Post#2771568
Well mike,
The consensus is it can't be done on a budget,
4dr 57
Reg: 11-10-04
07-26-19 06:36 AM - Post#2771644
After reading all the comments I just have to ask the OP if the car is indeed 'Stock' or simply looks like it.
These cars were engineered to travel at 60 - 65mph maximin.
Running down a highway at 70 with stock brakes or front disc conversion that has a lot of pedal travel . . . well, that's up to the driver. To me it seems more than just a bit careless/risky.
That said, most cars in general get the best mpg at 60mph, that's a fact. Older cars in stock form may be a bit lower - 55mph.
This leads to your engine and where it's torque band is. This is where performance and efficiency meet. I would suggest you put a pencil to it and figure out where the engine wants to be at a normal cruising speed and gear accordingly.
Just keep in mind when reading replies that modern engines are very torquey at low rpms (1800 rpm) while older engines actually are more efficient at a bit higher rpm. my $.02
I know there are probably other reasons for your wanting to change to an A/T other than HP, efficiency, etc.
Is opting for a 336 rear gear and keeping the 4 way in the cards? You will only be adding 250 rpm's to the cruising speed rpm, which may actually be beneficial to the engine at highway speed.
07-26-19 06:48 AM - Post#2771646
    In response to 4dr 57
Agreed on the gearing issue. In o/d with 3.08 gears, the final ratio is about 2.30, not a good set up.
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
07-26-19 08:30 AM - Post#2771656
Well Mike,
Sounds like you'll need to pull the rear axle
MikeH
Loc: Abington, MA
Reg: 09-24-02
07-29-19 04:27 PM - Post#2771954
Thanks to all for your ideas. All will be considered before I start this project.
I did notice a misprint I made in my original post...I have a 350ci/290 hp, not 390 hp.
MikeH
WagonCrazy
WagonCrazy
Reg: 06-07-05
07-29-19 05:16 PM - Post#2771958
Mike,
I did a 3 speed manual (column shift trans) to 200-4r (4 speed automatic-column shift) install on my 4 door wagon several years ago. Did it all myself, and it was a domino effect, but it was well worth it. Helped fuel mileage and general enjoyment when freeway driving.
The wagon had a stock 290 hp 350 ci engine and a 3:55 ratio rear end.
It ran at about 1800 rpm when at 70mph.
Documented it in these posts.
Enjoy...
3sp manual to 200-4r auto
200-4r conversion update
07-30-19 05:46 AM - Post#2771990
    In response to WagonCrazy
Either your tach is wrong or you have 32" rear tires. Put the numbers in. DO the math.
https://www.randysworldwide.com/calculators/rpm/
bowtie56jw
Reg: 03-02-09
08-01-19 02:28 PM - Post#2772188
i run 1800 at 70 in my 57 with a th200 4r and 3:36 gear but im also running 275 60 15's
4dr 57
Reg: 11-10-04
08-03-19 08:17 AM - Post#2772300
    In response to bowtie56jw
That sounds just about what I run at 70 in my 57 with a 4L60e 4dr and 323 ('64 pumpkin) but I'm also running 205 14's.
The engine is an 97 LT1. That's why I said that I suspect the OP new engine may like to run a bit higher rpm in order to get into the torque range the motor likes, but what that rpm is will be up to the OP and must include rear gears and tire sizing once he finds out where the engine wants to be.
My LT1 torque starts at 1800 and I am at 1950 at 70. So I drive 60 and get the best mpg.
Stan
5/7HEAVEN
Old as Dirt Member
5/7HEAVEN
Loc: In a quandry
Reg: 05-27-01
08-10-19 07:25 AM - Post#2772879
MikeH
Lol,I was thinking that's a very powerful crate motor.
'57 BELAIR sport coupe/383/4-speed
Execution time: 0.204 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:21 PM
