Username Post: Oil pressure sensor        (Topic#357300)
fuzz1957
Loc: NE IA
07-20-19 08:36 AM - Post#2771141
2005 GMC 5.3 will 81,000. Oil pressure gauge has gone to 80 psi. Looked on internet and seems to be a common occurrence - sensor goes bad. Not too hard to change. ? 1. Driving it this way shouldn’t cause any problems other than not having correct reading? Can I just drive it and ignore sensor/gauge, take my chances? ? 2. There’s a filter below oil pressure sensor. Does that need to be changed too?
Fuzz
MAGA
fuzz1957
Loc: NE IA
10-29-19 03:13 PM - Post#2779075
    In response to fuzz1957
I take it that the questions asked are too hard?
Fuzz
Matt
Matt
Loc: SAV
Reg: 09-26-01
10-30-19 12:11 PM - Post#2779131
Ah, wrong forum, I'm moving it. This was in the '07+ trucks
Edited by Matt on 10-30-19 12:13 PM. Reason for edit: moved to 99-06.
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
10-30-19 05:39 PM - Post#2779157
The sending units fail, Yes change it. No the filter gets changed next oil change.
george88gta
george88gta
Loc: new york
Reg: 04-23-03
10-31-19 04:22 AM - Post#2779182
    In response to junkman104
https://www.rockauto.com/info/42/926-040-007__ ra_p...
There is a filter, in the block, directly under the sender. Fits in the hole for the sender. If it is easily accessible, I would change it as well.
I have to admit, I have never seen one installed in an engine, could be model year specific, but if one is there, it is probably a good idea to replace it.
Edited by george88gta on 10-31-19 04:29 AM. Reason for edit: No reason given.
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
10-31-19 05:46 PM - Post#2779247
    In response to george88gta
Oops I read it wrong, I'm with George and never seen one as well.
wreckmech
Loc: Parsippany, NJ
Reg: 10-08-02
11-02-19 03:15 PM - Post#2779391
There is a small filter under the sending unit. Most people miss it, and therefore it never gets changed. I've seen them plugged with so much sludge that there is no pressure reading at all. I don't know if you can get them aftermarket, or not. I went to the stealership for the last one I needed.
george88gta
george88gta
Loc: new york
Reg: 04-23-03
11-02-19 04:09 PM - Post#2779395
    In response to wreckmech
They are available aftermarket and some senders come as a kit, sender and filter.
wreckmech
Loc: Parsippany, NJ
Reg: 10-08-02
11-03-19 12:19 AM - Post#2779420
Nice to know. The last one I did was 4, or 5 years ago. The engine had so much sludge that the oil galleries were plugged completely. There was no oil pressure reading at all....The bearings were almost completely disintegrated when I tore it down.
The owner was not happy, to say the least. I later found out he had only changed his oil once in 7 years..."to save money"...Needless to say, he now changes his oil regularly.
Execution time: 0.188 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:11 AM
