Username Post: Just swapped in a electric fule pump to replace a mechanical fuel pump        (Topic#357297)
jbander
Reg: 07-19-19
07-19-19 07:57 PM - Post#2771118
The engine is a 355 carbed engine in a 87 Camaro which did have a mechanical pump on it. I put in a Carter p4594 electric fuel pump (https://www.jegs.com/i/Carter/180/P4...B&gclsrc=aw.ds) and connected the pump to the tank and the existing fuel line and at the engine I by passed the mechanical fuel pump. and connected directly to the carb. I still have the mechanical on the engine disconnected from the tank and I closed off its return line back to the tank. The electric fuel pump is connect to a fuse in the fuse box with a jumper. This car still has the computer in it from when it had a fuel injected 305 in it. The pump stays on all the time , and it runs like hell.
So could this be a computer thing or should their be a pressure switch turning the pump on and off. It says 12lb pressure at the carb , the mechanical was 4 at the most.
I always leave out information that is needed so If You need more information just ask if you would , Thank you.
Senior Moderator
07-20-19 05:21 AM - Post#2771129
    In response to jbander
Way too much pressure for a carb. Look up your carb model but the recommended fuel pressure is likely closer to 6psi. A bypass-style regulator may be the answer.
jbander
Reg: 07-19-19
07-20-19 06:32 AM - Post#2771133
    In response to someotherguy
I changed fuel pump because I've added Nitrous and the nitrous calls from 8 to 10 psi. I'm by passing the ecm so what turns the pump on and off When the ecm is bypassed.
07-20-19 08:33 AM - Post#2771144
You can't regulate the fuel pressure by turning the pump on and off. The pump will run anytime the key is on. Normally, the only time the fuel pump is turned off on an EFI car, is when the key is on and the engine isn't running after 5 seconds or so. That's for safety reasons. A regulator is needed to lower the pressure or it will over come the floats and flood the engine.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
07-20-19 12:50 PM - Post#2771158
    In response to acardon
Edited by grumpyvette on 07-20-19 12:54 PM. Reason for edit: No reason given.
jbander
Reg: 07-19-19
07-20-19 06:37 PM - Post#2771183
    In response to grumpyvette
Good grief three regulators.
65_Impala
Reg: 12-29-02
07-21-19 07:37 AM - Post#2771222
You still have the EFI pump in the tank? That might be all the pump you need. Was it TBI or TPI?
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
07-21-19 07:56 AM - Post#2771225
    In response to 65_Impala
re-routing the lines can be done so only two regulators can accomplish something similar
Edited by grumpyvette on 07-22-19 08:58 AM. Reason for edit: No reason given.
jbander
Reg: 07-19-19
07-22-19 08:39 AM - Post#2771291
The EFI pump is gone or disconnected. and I'm Running a Carter p4594 now.Originally it had a 305 in it. Its a 87 camaro.
65_Impala
Reg: 12-29-02
07-23-19 05:38 AM - Post#2771362
Gone or disconnected... Gone means not in the tank anymore. Not sure what disconnected means, but it doesn't mean it's been removed.
The old efi computer would have nothing to do with some tap off the fuse block. 12PSI is too much for a carb. You should have some kind or protection for an accident like an inertia switch or pump operated from a oil pressure switch. The pump should also be powered from a properly installed relay circuit.
Overall, I suggest you learn how to build a proper fuel system before trying to use that nitrous.
jbander
Reg: 07-19-19
07-23-19 07:54 PM - Post#2771410
Thanks folk my regulator comes tomorrow.
jbander
Reg: 07-19-19
07-25-19 07:15 AM - Post#2771525
Learning about nitrous is exactly what I'm doing here. The regulator came and it is installed runs great.
Edited by jbander on 07-25-19 07:16 AM. Reason for edit: No reason given.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
07-26-19 09:52 AM - Post#2771663
glad to hear we could help
Execution time: 0.177 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:05 PM
