Username Post: 1939 Chevy car photos        (Topic#357280)
Spas602
"3rd Year" Platinum Supporting Member
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
07-18-19 05:39 PM - Post#2771011
Just got this 1939 Chevy. This is my first time working on a car this caliber. Just changed out the motor mount bolts to correct diameter.
What I know about this car:
350 crate motor with low hours
Th400 transmission
Mustang front steering components
Tilt wheel
4 wheel Disk brake setup
Cut firewall receding 2 inches
Headers
Ez wiring
Have back window
Powder coat frame
Hoping to put it back together. Is this car a deluxe or a coupe?
Attachment: E34F6C9F-6B80-4F67-8D02-B2DA9351C715.jpeg (3.61 MB) 33 View(s)
Attachment: 9841F7CC-9A25-4AF3-AE3E-602D70A830D7.jpeg (2.89 MB) 29 View(s)
Attachment: 184D63CD-AB5B-4C65-B3D4-9E7F79CCA6DA.jpeg (4.23 MB) 22 View(s)
Attachment: 721E958C-E502-4B85-88E2-599D58909829.jpeg (4.46 MB) 29 View(s)
Attachment: 052DF1E4-3CB5-46BB-BB8F-D272A4415C5D.jpeg (3.59 MB) 21 View(s)
My CT Build Page:
https://bit.ly/3dAB7Wx
Spas602
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
07-18-19 05:42 PM - Post#2771013
    In response to Spas602
Attachment: A2EDA648-1B44-4D34-8BEE-23FDD4C93DFD.jpeg (3.68 MB) 36 View(s)
Attachment: 0E9ED22D-BAFC-4365-86F5-1DC02D660C4F.jpeg (3.63 MB) 23 View(s)
Attachment: 21BBA33F-81B8-4306-82AA-DF6607F5AC11.jpeg (3.07 MB) 25 View(s)
My CT Build Page:
Edited by Spas602 on 07-18-19 05:43 PM. Reason for edit: No reason given.
07-18-19 07:23 PM - Post#2771021
It is a coupe. Does it have a back seat? Looks like it does have a back seat, that would make it a 5 passenger coupe.
29-41, 42-48, 49-54 Moderator
1946 Chevy 1/2 ton pickup, stock. Purchased 11/18/17. Sold 9/16/20
Spas602
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
07-19-19 01:52 PM - Post#2771086
Thank you sir. I appreciate it.
My CT Build Page:
07-19-19 06:44 PM - Post#2771107
Here is a link to your 39 Chevy Spec Pac
pauldian
pauldian
Loc: seligman,arizona
Reg: 05-14-09
07-19-19 08:26 PM - Post#2771115
Here is a link to my 39 master deluxe sport
sedan. Link
07-20-19 08:16 PM - Post#2771188
    In response to pauldian
Link doesn't work.
pauldian
pauldian
Reg: 05-14-09
07-21-19 11:16 AM - Post#2771232
Sorry,Works when I try it.
07-21-19 07:44 PM - Post#2771254
Probably because of Google having your signon an and password. I'm no expert about this stuff.
pauldian
pauldian
Reg: 05-14-09
07-24-19 07:09 AM - Post#2771432
Keith , Maybe this will work for you ?
https://lh3.googleusercontent.com/eYfyOpGR0e-0bzIy...
Spas602
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
07-25-19 08:55 PM - Post#2771607
Got the front end back on. The hood isn’t painted, so wiring is the goal.
Attachment: 24FE1AEC-EE85-43F7-B8FC-381CF90FCAA7.jpeg (2.93 MB) 24 View(s)
My CT Build Page:
1971BB427
Loc: Portland,Or
Reg: 12-06-09
07-29-19 08:27 AM - Post#2771904
Looks like a very nice car to begin a project with! Wish my '39 was that clean and far along when I got it!
I've been doing rust repair to the body for the last couple months, and still have a way to go with that. Once that's done I'm dropping in a 1990 roller motor with early LT1 heads. A 700R4 overdrive trans, and an 8.8" Ford rear in 3.73 posi.
A 5 passenger coupe will also usually have sliding rear 1/4 windows. Mine does.
Good luck with your build!
1969 Suburban 2wd 350
1939 Chevy pass. coupe 350/700R4
1937 Austin gasser 327/TH350
Spas602
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
07-30-19 05:55 AM - Post#2771987
    In response to 1971BB427
Thanks for the feedback. This car does have a Ford 9 inch rear end. No posi.
My CT Build Page:
Spas602
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
08-30-19 07:12 PM - Post#2774524
Got the car wired. Had some leaks of water, gas, and transmission. Starter was squeaking, so shim adjustments were made. Kept the car at steady idle to break it in. Fan engages around 180.
Next goal is to determine if the car has brakes, and engages into gear.
Attachment: CD57858C-CC6E-45BC-948A-3AFB3D52E659.jpeg (3.06 MB) 10 View(s)
Attachment: 9C156461-603B-407F-AB26-B44EB7211962.jpeg (3.53 MB) 13 View(s)
Attachment: A1D25A22-3EDC-4C6C-B559-E48A4BFE9DF3.jpeg (3.16 MB) 15 View(s)
Attachment: 0EFB6E20-DC6B-46CC-B86A-553EB95FBED3.jpeg (3.07 MB) 15 View(s)
My CT Build Page:
Execution time: 0.125 seconds.   Total Queries: 20   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:16 AM
