Username Post: Taking Power from the brown alternator output wire        (Topic#357271)
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
07-18-19 08:54 AM - Post#2770978
I asked on the AAW section but no response fiquired someone here might know.
Is it ok to tap 12v ignition power from the brown wire off the alternator(14.1 V). This wire activates when the engine is running and currently has a tap on it to operate a 12v vacuum pump for the power brakes which has a relay built in and is fused. See attached picture. I know the tap it self is not the best way but is it ok just to change it to a soldered connection. The fuse box inside is full and I don't want to put in a larger box.
Attachment: alternator_wire_tap.jpg (858.32 KB) 43 View(s)
Edited by turbo38s10 on 07-18-19 08:55 AM. Reason for edit: No reason given.
07-18-19 10:27 AM - Post#2770983
    In response to turbo38s10
Answered in the AAW post.
The excitor wire is not meant to carry current.
07-31-19 05:47 AM - Post#2772066
    In response to acardon
Agreed. I take power from positive battery post for most large current accessories.
'08 GMC Acadia 3.6L SLE
"16th Year" Platinum Supporting Member & Senior Moderator
08-05-19 05:25 PM - Post#2772477
And don't forget to put a fusible link or breaker of suitable size for the wire gauge or load. Don't risk a car burn down!
10-09-19 09:58 PM - Post#2777522
if you use that kind of tap in my shop , you will be looking for a job.
65_Impala
Reg: 12-29-02
10-10-19 09:06 AM - Post#2777553
The brown wire is a great way to trigger a relay only when the engine is running. Works for any application with an indicator light or resistor feeding the brown wire.
It will simply be ignition switched if the brown wire is directly ignition switched without a light or resistor.
Execution time: 0.123 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:17 PM
