Username Post: Rear Sway Bar        (Topic#357265)
50_Fastback
50_Fastback
Loc: California Central Coast
Reg: 09-08-14
07-17-19 03:19 PM - Post#2770932
Have any of you installed a rear sway bar in a '50 with a Nova rear end? Thinkin' about it but not sure where to start.
Ron Starkey
Life's full of risks..........take one!
'50 Fleetline 350/350
Mike JW
Mike JW
Loc: Arroyo Grande, CA
Reg: 01-19-06
07-17-19 05:12 PM - Post#2770939
    In response to 50_Fastback
Hi Ron
I have a rear sway bar in my 50. Its a 10 bolt out of a S10 4x4. I think there the same as the Nova. The sway bar is also out of an S10. Let me know if and when you go to Pismo Derelicts and you you can take a look.
07-17-19 05:27 PM - Post#2770940
CE system on my 51. A big improvement cornering, also Nova rear.
50_Fastback
50_Fastback
Reg: 09-08-14
07-17-19 06:06 PM - Post#2770943
Shepherd,
Thanks for quick response! Did a quick search for CE Systems couldn't find them. do you have any contact info and possibly a model number of the sway bar?
Ron Starkey
50_Fastback
50_Fastback
Reg: 09-08-14
07-17-19 06:07 PM - Post#2770944
    In response to Mike JW
Mike, I've been trying to get to Pismo but somehow my biological alarm clock never seems to go off
Ron Starkey
Edited by 50_Fastback on 07-17-19 06:08 PM. Reason for edit: No reason given.
07-17-19 07:03 PM - Post#2770947
DAMN!!!!!!!!!!!!!!!!!!!
What kind of cornering are you guys doing in your old Chevys????????
Oh, I see, some of you are road racing them, right?
johnwd98
johnwd98
Loc: Little Falls, MN
Reg: 09-05-10
07-18-19 05:21 AM - Post#2770965
JW, I have an S10 rearend in my Fleetline also. Looked at installing the rear sway bar from the S10 Blazer, but it looked like the fuel tank would be in the way.Curious to know how you mounted yours.
1950 Fleetline, 355 TBI, mild cam, 700R4, 3.73 posi rear Blazer axle, MII front. Remote door and trunk locks, GM cruise control, A/C,
40grit
40grit
Loc: Chattanooga, Tn
Reg: 07-08-13
07-18-19 05:48 AM - Post#2770966
    In response to johnwd98
I had a 1947 F@@d convertible with a late style rear end. I mounted a Mustang front swaybar upside down and backwards in order for it to clear everything. The swaybar does not care how it is mounted or what it is under. It just needs to be the right width to attach to the frame rails and line up with brackets attached to the bottom spring mounting plate. Obviously, the arms of the sway bar should be as level as possible but that can be adjusted by the length of the links.
As I remember, I made my links by taking a piece of allthread and using a piece of stainless tubing or small galvanized pipe around them which allowed the links to be whatever length I needed.
It's been a while and in those days it was a lot easier to browze the salvage yards for something that would work but maybe you have a "Pick and pull" yard in your area.
It is a project that can be done for next to nothing with a little hands on work.
Just Slightly Abrasive
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
07-18-19 06:08 AM - Post#2770968
Why do you need a Sway Bar, There's not a lot of room back to start with and cornering at high speed with the stock front suspension is not a good idea.
Mike JW
Mike JW
Reg: 01-19-06
07-18-19 06:22 AM - Post#2770969
Its mounted forward.
07-18-19 11:56 AM - Post#2770989
I see they are out of business now. Seems Heidts took over.
BAJohnny
Loc: Kentucky
Reg: 04-04-13
07-18-19 04:51 PM - Post#2771006
https://chassisengineerin ginc.com/
Try this address.
1953 BelAir 2dr Sedan
1953 BelAir 2dr Hardtop
07-18-19 06:00 PM - Post#2771014
    In response to BAJohnny
Yup, page 3 in the sway bar selections, this is what is on my 51. Just check that it fits the Nova housing diameter.
50_Fastback
50_Fastback
Reg: 09-08-14
07-18-19 08:12 PM - Post#2771029
    In response to cbmkr56
In the rear of my '50 is a 10" Nova rear end and long '68 Camaro leaf's. Up Front there is a Mustang ii IFS with dropped spindles, full length springs, Mustang sway bar and power steering.
On a recent trip through Oregon and Washington I found myself on some winding roads where I was rolling all over the place.
My assumption is that if I add a swaybar to the rear, Bilstein shocks all around and possibly a thicker swaybar up front the car will flatten out.
I'm not interested in racing but being caught in a stream of cars on a narrow winding road with handling problems is an experience I would not like to repeat.
Ron
Ron Starkey
Edited by 50_Fastback on 07-18-19 08:22 PM. Reason for edit: No reason given.
50_Fastback
50_Fastback
Reg: 09-08-14
07-18-19 08:18 PM - Post#2771030
Shepherd,
IS this it? Chassis Engineering
SB-1054RA Rear Sway Bar for 1949-1954 Chevy
SKU: SB-1054RA
$185.00
Attachment: Sway_bar.jpg (17.52 KB) 4 View(s)
Ron Starkey
hpva
hpva
Loc: Kinderhook NY
Reg: 03-31-13
07-19-19 04:44 PM - Post#2771092
  • 50_Fastback Said:
Shepherd,
SKU: SB-1054RA
$185.00
I bought this one for my 54 this spring but I haven't installed it yet.I think Heidts bought out Chassis Engineering.
07-19-19 05:10 PM - Post#2771097
Yes, that's the one I installed.
Mel Foye
*VIP* Founding Member
Mel Foye
Reg: 09-29-00
07-19-19 06:39 PM - Post#2771106
My thinking and experience whether on the track or doing 15mph around an easy city corner the less roll the better the ease of cornering. With less roll the tires stay flatter on the road and to me the driving is just more enjoyable.
I do have a concern and it is when a rear bar is added you want to be sure it complements the front bar.
Enjoy all the changes you make.
50_Fastback
50_Fastback
Reg: 09-08-14
07-19-19 06:45 PM - Post#2771108
Shepherd one last question,
Do you have lowering blocks installed?
Thanks!
Ron
Ron Starkey
50_Fastback
50_Fastback
Reg: 09-08-14
07-19-19 06:59 PM - Post#2771112
    In response to Mel Foye
Mel,
How would you describe the rear bar complementing the front bar? Thickness?
Thanks,
Ron
Ron Starkey
Edited by 50_Fastback on 07-19-19 07:01 PM. Reason for edit: No reason given.
07-20-19 04:22 AM - Post#2771125
No, Posies lowering springs, lowered spindles in the front.
johnwd98
johnwd98
Reg: 09-05-10
07-20-19 06:13 AM - Post#2771128
JW, Thanks, hadn't thought about mounting it forward.Might have to add that to my Winter project list. A couple of Summers ago I drove my Fleetline to Deadwood SD for Kool Deadwood nites (about a 1200 mi. round trip). Near Rapid City, SD on I90 where the speed limit is 80 and as we all know a lot of people drive faster. Anyway while keeping up with the flow of traffic, I90 became a little curvy, bumpy, and windy. Decided I needed to slow down because of the poor handling under those conditions...not to mention the wife's comfort lol. Don't enjoy white knuckle driving like I used to.
Mike JW
Mike JW
Reg: 01-19-06
07-20-19 10:05 AM - Post#2771147
I know what you mean.
Snegrah
"3rd Year" Platinum Supporting Member
Snegrah
Loc: Pacifica, CA.
Reg: 04-28-04
07-20-19 09:56 PM - Post#2771191
I was told that a front sway bar is better than none and if a rear one is installed, the front should be thicker than the rear.
51 Chevy Bus. coupe 261 6cyl 5 speed
53 Chevy Bus. coupe 350/700R/AC
49 Chevy P.U. 350/700R/AC
51 Chevy sedan delivery - project
Mike JW
Mike JW
Reg: 01-19-06
07-27-19 04:01 PM - Post#2771742
Glad you made it to Pismo, this AM. It was nice to meet you and see your car. Wish I'd have brought my 50 instead of the 51 pickup, maybe next time. Hope to see you there again soon. Mike
50_Fastback
50_Fastback
Reg: 09-08-14
07-30-19 08:16 PM - Post#2772039
Just received the Chassis Engineering Sway Bar and haven't even opened it. Probably be another week before I give it a shot.
Ron Starkey
Execution time: 0.065 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:38 AM
