Username Post: Taking power from Alternator Brown wire        (Topic#357263)
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
07-17-19 01:24 PM - Post#2770921
Is it ok to 12v ignition power from the brown wire off the alternator(14.1 V). This wire activates when the engine is running and currently has a tap on it to operate a 12v vacuum pump for the power brakes which has a relay built in. See attached picture. I know the tap it self is not the best way but is it ok just to change it to a soldered connection. The fuse box inside is full and I don't want to put in a larger box.
Attachment: alternator_wire_tap.jpg (858.32 KB) 26 View(s)
07-18-19 10:21 AM - Post#2770980
    In response to turbo38s10
I'm not AAW, but the exciter (brown) wire on the alternator was not meant to carry any current. I'm supprised the regulator hasn't blown with the load of a vacuum pump and that the indicator light works as it should.
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
07-18-19 10:53 AM - Post#2770984
    In response to acardon
It shows as being an igniton circuit according to the drawing here. Terminal# 1, Terminal #2 goes back to battery.
Attachment: AlternatorWiringOverview-1973to1985Buick.jpg (60.12 KB) 23 View(s)
07-18-19 11:13 AM - Post#2770986
The brown wire is a ground path through the indicator light and resistor. The alternators #1 terminal supplies a path to ground if the alternator isn't charging, to light the indicator light. When the alternator is charging, the #1 terminal's voltage goes up to equal the voltage of the ignition terminal and turns the light out, because there is no voltage difference between the #1 terminal of the alternator and ign1. No current flows in the brown wire when the alternator is charging.
IgnitionMan
Reg: 04-15-05
07-26-19 09:28 AM - Post#2771654
I'd take a look at the fuse box and see if there is a dedicated IGN or IGNITION terminal, and if so, use that.
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
07-26-19 10:18 AM - Post#2771659
    In response to IgnitionMan
Thats my problem it already has 2 items there and I don't want to put a 3rd.
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
08-04-19 08:49 AM - Post#2772380
Probably not. That is not my harness so it's tough to say. Usually, that wire has a resistance wire in series on it and only has about 2-4 volts on it.
Donny
65_Impala
Reg: 12-29-02
10-10-19 04:44 AM - Post#2777530
The brown wire is a great way to trigger a relay that turns-on only when the engine is running.
The circuit must have an indicator light though or else it just works as an ignition switched relay. You can check which way the circuit will work by measuring the voltage on the wire while connected with the engine off. If the voltage is low, like 2-4V then the relay will only trigger with the engine running.
Execution time: 0.203 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:58 AM
