Username Post: Engine sits high        (Topic#357259)
Airlifter
Airlifter
Reg: 06-07-15
07-17-19 07:03 AM - Post#2770898
After I installed the 261 engine I had to extend the transmission linkage. I thought that maybe we bent the rod during installation so didn't think much about it at the time. I then noticed that the top of the air cleaner was hitting the underside of the hood and when I checked underneath I saw that the oil pan to idler arm clearance was much more than before. I checked the distance between the top of the motor mount to the oil pan rail and it is seven inches (same as the mounts on the 235).
Is there something obvious that I am overlooking here?
Thanks, Pete
1951 styline deluxe sport coupe w/'60 261 engine & 54 powerglide
Idaho
Idaho
Loc: Upstate New York
Reg: 03-02-07
07-17-19 07:15 AM - Post#2770900
    In response to Airlifter
What motor mounts did you wind up using? Can you take photos?
1953 210 Chevy convertible, 1953 210 Chevy Handyman station wagon, 1957 GMC Suburban Carryall.
Airlifter
Airlifter
Reg: 06-07-15
07-17-19 02:28 PM - Post#2770927
    In response to Idaho
I used the towers that were there for the 54 235 and used motor mounts from Davis Speed shop. As I mentioned before, the distance from the top of the Davis motor mounts to the top of the oil pan rail on the 261 is the same as the top of the mounts on the 235 to the top of the oil pan rail.
Thanks for the response, Pete
drtyler
Loc: Georgia
Reg: 05-06-10
07-17-19 04:30 PM - Post#2770938
So the transmission and driveshaft are installed and look right, but the engine is just sitting high?
07-17-19 07:50 PM - Post#2770948
    In response to drtyler
When I installed a 261 in my '53 I located it too high the first time too. In my case I made my own motormount brackets and just made the first set wrong. Second set came out right.
Question: Can you remove the valve cover and reinstall it easily, or does the firewall bulge into the pass compartment interfere with the end of the valve cover.
IgnitionMan
Reg: 04-15-05
07-17-19 07:55 PM - Post#2770950
You might take a tape measure and measure from the engine mount pads on both engines, to the top of the engine, then from the pads to the bottom of the pan. I don't remember, but the two engjnes might be different heights, or, the pads on the blocks might be in different places.
Make sure the mount pedestals are the right height as well. I realize you are working with an I6, but GM used different pedestals for some of their engines in the later V8's, might have done same with some of the b's too.
100fires
100fires
Loc: Santa Fe Springs, Ca
Reg: 04-15-15
07-17-19 08:20 PM - Post#2770953
    In response to IgnitionMan
I used Davis 261 mount in my 54 and had similar issue I emailed them and they were very responsive. I trying to remember what I finally did to fix it and think the issue was how the transmission was sitting. I do not know if it put the solution in my post but I did post asking for suggestion. You can look for my post.
Execution time: 0.092 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:49 AM
