Username Post: Aluminum diamond plate bed        (Topic#357233)
doubleE
Loc: Eagan MN
Reg: 06-02-03
07-15-19 07:38 AM - Post#2770729
My 72 fleet side short bed with the steel floor has cancer. I see there are choices like buying a repo steel floor or converting to a wood floor - both expensive and labor intensive.
Since the floor is still structurally sound I've thought of treating it with a rust conversion product then lay a diamond plate aluminum sheet on top of the steel floor.
I would think this would be a popular option but a internet search for a fitted sheet does not seem to exist. I have seen other trucks at shows with this and looks nice (if not original). What I plan to check out is to go to a local metal supply store and see what a sheet would cost and if they would be able to cut out the wheel wells. I'll post what I find out.
Double E
Edited by doubleE on 07-15-19 07:40 AM. Reason for edit: No reason given.
doubleE
Loc: Eagan MN
Reg: 06-02-03
07-15-19 02:40 PM - Post#2770767
    In response to doubleE
I may have found another solution. I started looking for rubber bed mats for vintage trucks. Much to my dismay none of the well known brands make a mat for 60 - 72 fleet sides. There was a universal fit that would work for step sides.
But after a couple hours of googling I came across QuietRide Solutions Link found this - perfect for my needs. Chevy truck mat They shouldn't be so hard to find, a search for "vintage pickup truck bed mats" on several search engines failed to bring them up. It was only going through a couple dozen pinterest pictures tell I spotted it
I will follow through pricing out the aluminum plate but guessing the $209 + shipping will be hard to beat. I went to the metal store in my town today only to find it went out of business. I requested quotes from a couple other suppliers near by.
Silver Blue
Keith Seymore
Keith Seymore
Loc: Southeast Michigan
Reg: 09-17-08
07-22-19 10:22 AM - Post#2771303
If you use your truck to haul anything at all (even small parts) I think you will prefer the mat to the aluminum plate.
K
Chevelle Intro: http://www.popularhotrodding.com/features/1005phr_...
My Pontiacs: http://forums.maxperformanceinc.com/forums/showthr...
Pickup: http://67-72chevytrucks.com/vboard/showthread.php?...
Execution time: 0.14 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:04 AM
