Username Post: Alternator bracket, driver side        (Topic#357228)
df0rster
Reg: 10-25-18
07-14-19 07:31 PM - Post#2770708
My ‘67 has a 69+ 454 with a long water pump. I want to put the alternator on the drivers side because the factory harness locates it there and the ac compressor is on the pass side. . I’ve found that long water pump brackets are only made for the pass side or you can find lower brackets for the lower drivers side. Which is where the ps pump goes.
So has anybody ran into to a similar problem? Other option is to get a short water pump (if they fit this 454 engine) and then just get the alt brackets for the drivers side.
65acadian
65acadian
Loc: Manitoba, Canada
Reg: 08-15-04
07-14-19 09:44 PM - Post#2770714
    In response to df0rster
I think this answers your question, you can put all 67 396 stuff right on to your 454 but of course you have to put the short pump on as well.
df0rster
Reg: 10-25-18
07-15-19 05:40 AM - Post#2770723
    In response to 65acadian
Yes that was kind of what I was figuring out. I’m just not sure why there isn’t a bracket to locate the alternator on the upper drivers side with a long pump. Surely someone else has wanted that. But I think even if I could find a special bracket it might be cheaper for me to just replace the water pump. They aren’t expensive and mine is old and unknown anyway.
100 CHEVY
Deceased Member RIP
100 CHEVY
Loc: Helena,Missippi,U.S.A.
Reg: 12-09-04
07-16-19 06:45 AM - Post#2770824
Look at Allen Groves stuff (and other aftermarket suppliers)for a bracket before you change things up.
If you go with the short pump,you'll find the brackets to use it are getting hard to find too.
I've a 454 in my 65 and it took a while to find all the correct stuff for it to use the short pump.And,they are not cheap!
Mike.
"16th Year" Platinum Supporting Member & Senior Moderator
07-16-19 10:18 PM - Post#2770876
    In response to 100 CHEVY
As I remember, the pulleys are different as well.
df0rster
Reg: 10-25-18
07-17-19 05:20 AM - Post#2770888
Thanks!
I don't even care to have the short pump really but I wanted the alternator on the drivers side due to all the wiring harness stuff and the AC stuff being on the pass side. Seemed logical.
I did order a short pump and pulleys, so hopefully it will work. I'll post some pics after I install it. It wasn't expensive compared to some of the custom brackets I've been seeing.
59fins
Member #212 "20th Year" Gold Supporting Member
59fins
Loc: Surprise Az USA
Reg: 04-07-00
07-17-19 09:39 AM - Post#2770908
This is exactly what I did.
Bill H.
67 SS
emil
"6th Year Platinum Supporting Member
emil
Loc: Belle Mead, N.J.
Reg: 07-02-12
07-21-19 08:23 AM - Post#2771217
Agree with "100 Chevrolet." Look at Alan Grove kits which I have installed on at least 2 69 "B" bodies.
I believe he offers kits, or at least he did, for both short and long water pump applications.
emil
69 Kingswood 4-sp
69 Impala SS 4-sp
66 Biscayne 511 BB Legends 5-sp
69 Biscayne 468 BB 4-sp
71 BelAir 250 250-6 3-sp
95 Caprice Classic wagon
2000 2500HD Chev 5-sp
2016 Ram Rebel
4 Harleys
df0rster
Reg: 10-25-18
07-25-19 05:31 AM - Post#2771512
    In response to emil
Too bad I didn't check out the alan groves stuff before I bought a bunch of parts.
but in the end I am happy because I got all my accessories back where they originally were so it will fit up better with the wiring and AC stuff. And I think the cost was much less going with the short water pump setup. I found stock brackets for everything to get it back to original.
Edited by df0rster on 07-25-19 05:31 AM. Reason for edit: No reason given.
Execution time: 0.105 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:05 AM
